You need to take this step-by-step.
The first step is to choose the remote and then capture the signal from the keys you want to use. See http://davehouston.org/learn.htm for a simple way to do this.
Thanks for the response dhouston. I looked over the information. I think that is were I eventually want to get to. However, I don't think I am ready to take that big of jump yet.
I have been working on trying to do simple IR communications between 2 PICs. I basically used the codes from http://www.rentron.com/Infrared_Communication.htm.
I used a PIC627 with this code for the PWM and SEROUT.
And I used a PIC628A with this code for SERIN. The code Rentron had listed was BS2 code. I did my best to convert it to picbasic. I used SERIN2 instead of SERIN.Code:DEFINE OSC 4 TRISB.3 = 0 ' CCP1 (PortB.3 = Output) PR2 = 25 ' Set PWM Period for approximately 38KHz CCPR1L = 13 ' Set PWM Duty-Cycle to 50% CCP1CON = %00001100 ' Select PWM Mode T2CON = %00000100 ' Timer2 = ON + 1:1 prescale TRISB.0 = 0 ADDRESS VAR BYTE DAT VAR BYTE ID VAR BYTE ADDRESS = 10 ID = 25 BEGIN: FOR DAT = 0 TO 255 SEROUT PORTB.0,4,[ID,ADDRESS,DAT] PAUSE 100 NEXT GOTO BEGIN END
Was it okay to use SERIN2 with SEROUT?Code:DEFINE OSC 4 CMCON = 7 VRCON = 0 TRISA = 0 TRISB = 1 SYNCH CON 25 'Establish synchronization byte BAUD CON 396 'NON INVERTED 2400 baud (MAX) DAT VAR byte 'Data storage variable ADDRESS VAR BYTE START: SERIN2 PORTB.0,BAUD,[WAIT(SYNCH),ADDRESS,DAT] PORTA = DAT GOTO START END
I connected 4 LEDs to porta.0 thru porta.3. I am getting a response from the LEDs. I am just not sure if it representing the correct data. When I try something like:
I get the correct LEDs to light up initially for about a second. Then, the other LEDs start flashing.Code:ADDRESS VAR BYTE DAT VAR BYTE ID VAR BYTE ADDRESS = 10 ID = 25 DAT = 10 BEGIN: SEROUT PORTB.0,4,[ID,ADDRESS,DAT] PAUSE 100 GOTO BEGIN END
I will continue to experiment and hopefully I will get the communications figured out.
I do have a question about the schematic Rentron uses for the IR Transmitter. Is there a reason why 2 Infrared LEDs are used to transmit the signal?
If you eventually want to use a remote, then all of this is just a waste of effort as 99.99% of remotes do not use RS232 communications.You get twice the IR signal strength for the same current.I do have a question about the schematic Rentron uses for the IR Transmitter. Is there a reason why 2 Infrared LEDs are used to transmit the signal?
If your "carrier true" signal is incrementing because of looping, then you can simply count one, then sit and loop (no more counting) until the carrier detection returns a FALSE state, after which you drop out of the loop and wait for the next "button press". Kind of like switch debouncing, but different.
picster
Hello Partime,
I made a self-learning IR remote (with lots of help from people in this forum).
Maybe you can help some helpfull stuff in the code (especially LEARN and SEND routines).
Have a look here http://home.citycable.ch/flotulopex/...I_Frames_e.htm
Roger
Thank you picster and Roger for the information you presented.
I finally captured the signal from my remote as dhouston suggested. I couldn't get Loop Recorder to capture the signal, but I did get it with a different program (http://www.passmark.com/products/soundcheck.htm). I attached a copy of the signal I captured. It is from a Hitachi CLU-5722TSI remote's channel up button. The bottom one is the full signal. The top ones are of the signal divided into two segments.
The signal seems to follow this protocol that I found for Hitachi.What should the next step be? Should I try to write some code using PULSIN to read the incoming IR signal?Code:Code length: 32 bits Carrier: 39.2kHz The code is only transmitted once, and after that a stop code is transmitted. +--------------------------------+ Header: | | + +----------------+.. 16T 8T 8.8ms 4.4ms +--+ 1 is coded: | | ..+ +------+.. T 3T +--+ 0 is coded: | | ..+ +--+.. T T +--+ | | After the last bit a ( ..+ + ) is transmitted to terminate the last bit. T +--------------------------------+ +--+ Stop code: | | | | + +--------+ + 16T 4T T 8.8ms 2.2ms T = 550us
