newbee also wants to know about cmcon=7
Results 1 to 7 of 7
    Sep 2008
    Default newbee also wants to know about cmcon=7
    I just started with PICbasic pro and trying to put the cmcon=7 but when I compile it, an error says (undefined symbol cmcon). I'm using the 16f877a chip.
    Quote Originally Posted by lecoind View Post
    Are you sure you have selected the 16F877A and not the 16F877
    Sep 2008
    Default cmcon=7
    THE ONLY CHOICES I HAVE IS THE 16F877 IN MICROCODE STUDIO. I HAVE HAD THE PROGRAM FOR ABOUT 4 YEARS NOW. IT MIGHT BE OUT DATED BECAUSE IT DOES NOT LIST THE 877A. HOW WOULD i UPDATE?
    If it was new four years ago it should have it.
    What version of MCS and PBP do you have?
    Go here for update info
    http://www.melabs.com/products/pbp.htm
    Sep 2008
    Default version pbp
    I have version mcs 2.43 I'm trying to fine out what version pbp is.
    PBP 2.42 started support for the 877A.
    You can download the free version of MCS here
    http://www.melabs.com/resources/win_ide.htm
    but I am not sure if it works with the old versions of PBP, it should.
    If you still have you receipt for PBP or remember the company you purchased it from and they still have records from that far back, the upgrade is only $25.00 US.
    The new version of PBP has come a long way from 2.43. Would be worth the upgrade.
    Hangover, Germany
    Angry
    Why are you screaming so loud here ?????
    The 877a has options and registers not know by the 877 (without a).
    So, switch to the right compiler-option or read the datasheet so declare the register on your own.
  1. Read the newbee threads, 16F877A no go.
    By BobbyA in forum mel PIC BASIC Pro
    Last Post: - 31st December 2006, 04:09
  2. Newbee How to get LCD to display 4-6 var words
    By emmett brown in forum mel PIC BASIC Pro
    Last Post: - 15th August 2006, 02:11
  3. Newbee how to run pval back if if b0 < b1
    Last Post: - 11th July 2006, 14:02
  4. Replies: 2
    Last Post: - 10th July 2006, 02:05
  5. Replies: 2
    Last Post: - 13th December 2005, 01:11
