neebee wants to know pullup or pulldown?
Results 1 to 6 of 6
    Sep 2008
    Default 1 or a 0 for triggering
    ok Tenaja, I understand the internal pullups but what I realy want to know is if you were designing a circuit with switches controlling inputs, would you use
    a 1 to trigger the input or a 0 to trigger the input. I can design it eather way. I have had some people say keep all inputs (pulldown) normaly to ground until you trigger with a +5v and then some say always have a +5v pullup and ground the pin to trigger. Which is the prefered method?
    Sep 2008
    Default Bodgan, great link
    Bodgan, that was a great link. That relay let me know about pullups and pulldowns. Thanks
    Quote Originally Posted by lecoind View Post
    It all depends on the external hardware. That is what will determine the method.
    Is the switch normally high or low? Is the switch normally closed or open? That is the beauty of it, flexible.
    Unused pins can be pulled low with a 10K or higher.
  1. RB0 + Internal Pullup + Interrupt
    By Freman in forum mel PIC BASIC Pro
    Last Post: - 10th August 2009, 12:11
  2. PortD on 18f4550 cofig pullup for switches
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 16th April 2009, 13:00
  3. pullup and pulldown resistor help
    By studysession in forum General
    Last Post: - 29th January 2009, 03:46
  4. switch on 1 weak pullup on portb?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2008, 19:32
  5. Config word / pullup resistors
    By Tomexx in forum General
    Last Post: - 25th November 2004, 17:50
