Pulsin problem?
Results 1 to 4 of 4
Thread: Pulsin problem?
    Wink
    here, you are supposing your ECU Outputs a perfectly square wave ... is it real ???
    At 1000 rpm or 16.667Hz, my LCD screen shows 950-1050 (hightime is around 1500counts)
    ??? 1500 counts are 3 ms @ 20 Mhz ... 6ms ( square wave ) per rev is ... 10 000 rpm !!! ... not 1000.
    you have a calculation error somewhere !!!
    let's say 15000 counts ...
    60 000 000 / 2 / 2 / 15000 = 1000
    60 000 000 is 60 Million µs in a minute
    2 is for square wave ( you measure half duration )
    2 is for 2 pulses per rev ( matches your DVM result ... hé,hé )
    15000 is Pulsin result.
    also see DIV32 for 60 E6 ( or 15 E6 ! ) value use ...
    You'd better use " interrupts on edge " that would measure the full cycle ( High + Low parts of the signal ) regardless of the duty factor of your pulse ...
    see " DT Instant interrupts " for that ... works great ++ aboard my Honda lawn tractor ( lol )
    May 2009
    Yeah, I have no idea how the pulses look nor do I have equipment to see it.
    Acetronics, you are right about the hightime, it is 15000, I forgot I was looking at the number divided by ten on screen.
    I'll try using interrupts, it will work that way but it'll take me a while to get my head around it.
    Thanks.
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 13:52
  3. pulsin followed by serin2 problem
    By RSSHARPE in forum mel PIC BASIC Pro
    Last Post: - 18th September 2005, 09:50
  4. a problem RF Signal with PULSIN
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2005, 16:42
  5. Replies: 11
    Last Post: - 13th July 2005, 19:26
