random problem
Results 1 to 6 of 6
Thread: random problem
    Oct 2007
    The Netherlands
    Okay, I did a little test:
    If I try this code:
    loop:
         random temp
         toggle LED
         pause temp >> 8
    goto loop
    My LED flashes in a very nicely random way.
    If I try this code:
    loop:
         random temp
         temp = temp >> 8
         toggle LED
         pause temp
    goto loop
    Then it does not flash in a nicely random way.
    So... the seed must not be modified.
    But anyway this still does not explain why my morse code flasher doesn't work. Unfortunately I do not have the circuit at hand (it's in Paris now) so have to probably build a second one to really test.
    Dec 2005
    So Cal and loving it
    What about using your adcin 'audio' value as the seed - it seems like it should give you some randomness.
    | PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
    Oct 2007
    The Netherlands
    Hmm that's a good idea, will try, thanks
  1. Random Numbers
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 18th December 2008, 08:47
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  3. Another Serin/Serout Problem!
    By jmbanales21485 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 16:26
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
  5. 6 random numbers limiting to 49 ?????
    Last Post: - 15th June 2005, 23:27
