ADC and SEEPROM on 16F877A
Results 1 to 9 of 9
    Default ADC and SEEPROM on 16F877A
    I am having a problem combining using ADC on channel A0 and saving data to a SEEPROM on portB.0 and 1. Individually I can get each to work, displaying the results on an LCD (on PortC). But when I try to combine them using the following code, I only get 255 read back as what is being stored in the SEEPROM (which is a 24LC512). But the Temperature readings are being read properly, which tells me I have the ADC part working, but not the I2C part. It seems as though the ADCON1 statement is what is causing it, but I don't know why that would have anything to do with I2C.
    I am still learning, and I've looked for a similar program but could not find anything that resembles my program. Any help would be appreciated.
    Thank you,
    ' Define A/D converter and LCD parameters
    DEFINE ADC_BITS 8 ' A/D number of bits
    DEFINE ADC_CLOCK 3 ' Use A/D internal RC clock
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in us
    Define LCD_DREG PORTC
    Define LCD_DBIT 4
    Define LCD_RSREG PORTC
    Define LCD_RSBIT 3
    Define LCD_EREG PORTC
    Define LCD_EBIT 2
    ' Variables used
    Res Var Byte ' A/D converter result
    Temp1 Var Byte ' Temperature in degrees F
    Addr Var Byte ' Address of EEPROM
    CPin var PortB.0 'Pin for the SEEPROM Clock
    DPin var PortB.1 'Pin for the SEEPROM Data
    I var byte 'Variable for Collecting Data For/Next Loop
    RI var byte 'Variable for Results Reading For/Next Loop
    WB var word 'Varable for Waiting for Button Loop
    TRISB.7 = 1 'Pin used for Button
    PAUSE 500 ' Wait 0.5sec for LCD to initialize
    ' Clear display and display message "COLLECTING DATA…"
    lcdout 254,0
    lcdout 254,1,"Collecting DATA>"
    ' Initialize the A/D converter
    TRISA = %11111111
    ADCON1 = %00000010
    '==========================Colect Data======================================
    CollectData:
    FOR I = 0 TO 60
    ADCIN 0, Res ' Read Channel 0 data
    Temp1 = Res - 40 ' Calc Adjustment to degrees F
    I2CWrite DPin,CPin,$A0,Addr,[Temp1]
    lcdout 254,192,dec3 Addr, " : ", dec3 Temp1
    PAUSE 10 ' Wait 1 msecond
    gosub WaitForButton
    NEXT I ' Repeat
    lcdout 254,0
    lcdout 254,1, "Results"
    goto DoneCollecting
    '===========================Wait For Button=================================
    WaitForButton:
    For WB = 1 to 600
    if PortB.7 = 1 then Results
    pause 10
    Next WB
    '=============================Done Collecting================================
    DoneCollecting:
    pause 10
    goto DoneCollecting
    '===============================Results=========== ==========================
    Results:
    lcdout 254,0
    FOR RI = 0 TO 60
    I2CRead DPin,CPin,$A0,Addr,[Temp1]
    pause 1000 'Wait one second
    NEXT RI
    END ' End of program
    Default Re: ADC and SEEPROM on 16F877A
    I do not see a value assigned to the Addr variable.
    Yes, I did see that, and corrected it, and now what it is reading back after the 60 readings are taken, is numbers that don't match what I saw when the readings were being taken. For example, the readings start out at about 75 and I cause the thermistor to go up to about 85 and slowly come back down, to have some variation. The readings being read back are 255, 7, 9, 13, 255...255.
    I have update my code to read as follows:
    Define LCD_DBIT  4
    Define LCD_RSBIT 3
    Define LCD_EBIT  2
                    ' Variables used
    RAddr var byte           'Variable for Address of SEEPROM Results
    TempR var byte
    lcdout 254,0
    TRISA = 111111
    ADCON1 = 000010
    'ADCON1 = 7
    CollectData:
    FOR I = 0 TO 60
        Addr = I
        gosub WaitForButton
    NEXT I               ' Repeat
    lcdout 254,0
    goto DoneCollecting
    WaitForButton:
    For WB = 1 to 600
        pause 10
    Next WB
    DoneCollecting:
    pause 10
    goto DoneCollecting
    '===============================Results======================================
    Results:
    lcdout 254,0
    FOR RI = 0 TO 60
        RAddr = RI
        I2CRead DPin,CPin,$A0,RAddr,[TempR]
        lcdout 254,192,dec3 RAddr, " : ", dec3 TempR
    NEXT RI
    Addr Var Byte
    Should be
    Addr Var WORD
    I think....
    Dec 2012
    I did see this in your code and maybe it's just me, but in your new code, I saw this part:
    TRISA = 111111
    ADCON1 = 000010
    try changing it to and see if it helps:
    TRISA = %11111111
    ADCON1 = %00000010
    also, I thought you could use byte for that also due to being able to count clear up to 255 with 8 bits.
    That's most likely the forum messing up the posts.
    You can switch between two different editors when making posts in the forum, one of them keeps messing up like up that no matter what you do.
    If you look in the Forum Requests section you'll find requests for a fix. It's just a bit sad that a forum dedicated to PBP code can't show PBP code properly. Yes, the problem is known, yes the fix is to use the "correct" editor but new users and users who normally only come here when they're in trouble doesn't know that, makes a post with the "wrong" editor and the code in their post gets messed up. Then a year from now someone else finds the thread when looking for something, copy-pastes the messed up code which then doesn work and....
    Yes, HenrikOlsson , if you look at my original post, (the one that I forgot to put the CODE quotes around) you'll see the ADC Initialize part correct, and that is how it should have appeared in my subsequent post.
    mackrackit , I'm with Chirpy - I didn't think I would need to use WORD instead of BYTE unless I was using 10 bit, but after changing it in my code, it isn't the case. I would have thought that I only would have to change the WB var to a WORD since it counts up to 600, but I changed all var's associated with the address as well, and it is now working perfectly!! Not sure I understand why though. I first tried just changing WB to a WORD, and still had the same incorrect results. I know I also need to clean up the code a little too - not sure why I have 2 var's for the address, but I did need to change them both in both the I2CWrite and I2CRead commands.
    Thank you all for your help!!
    The address is 16 bit on this EEPROM, that is why the variable for it needs to be WORD size. It has to have all the places filled. It is in the data sheet.
    Awesome!! Thank you!! Gotta read the Data Sheets!!!
  1. New software filter for adc reading
    By aratti in forum Code Examples
    Last Post: - 6th August 2024, 21:35
  2. Help with multiple ADC inputs
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 4th January 2013, 00:27
  3. 12cwrite not working with 24LC08 SEEPROM ??
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 28th July 2010, 14:26
  4. 16f877a
    By alaaodeh in forum mel PIC BASIC Pro
    Last Post: - 6th February 2007, 23:38
  5. I need help with 16F877A
    By valerij in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 17:05
