Binary Coded Decimal
Results 1 to 12 of 12
    Jul 2007
    Default Binary Coded Decimal
    How do i convert bcd values to decimal, and decimal to bcd.
    eg bcd :0010 0011 = 23
    how would i convert that to 23 in decimal
    sinoteq's Avatar
    sinoteq Guest
    Shift right is one way.
    DEC_Out Var Byte
    BCD_In Var Byte
    DEC_Out=(BCD_In>>4*10)+(BCD_In & %00001111)
    This should in theory take the 4 Highbits and shift them right 4 times. Then multiply this result with 10 and add the 4 low bits putting the result in DEC_Out.
    To do the DEC to BCD you can use the DIG command it is really good for this.
    Jul 2007
    HI thanks that works great
    i'm using a real time clock and the only issue i have now is that when seconds reaches 40 the hours increments to 40
    the hour register is only 6 bits long bits 6 and 7 are not used, would i have to shift by less than 4 compared to the other registers
    Quote Originally Posted by sinoteq View Post
    DEC_Out Var Byte
    BCD_In Var Byte
    sinoteq's Avatar
    sinoteq Guest
    Real Time Clock, show us the code and we can advice. Or search the forum because most RTC has code examples or parts of examples that you can reuse in an easy way.
    Many RTC has mixed registers so you have to do some woodoo activities to sort out the information you want from it
    Jul 2007
    @ device  pic16f870,WDT_OFF            'Watch Dog Timer Disabled
     @ device  pic16f870,PROTECT_OFF        'Code Protect Off
     @ device  pic16f870,XT_OSC             'Using External Oscillator
     @ device  pic16f870,BOD_OFF            'Brown Out Timer Disabled
     @ device  pic16f870,PWRT_OFF           'Power On Timer Disabled
     @ device  pic16f870,LVP_OFF            'Low Voltage Programmed Disabled
    ADCON0.0=0
    ADCON1=7 ' ALL PINS SET TO DIGITAL
    TRISB = %00000000
    TRISA = %00000000
    TRISC.0=0
     'rtc pins
    clk_pin var portc.5
    data_pin var portc.6
    number var  word
    display VAR PORTB
    segment var PORTA
    seg_number var byte
    digit var byte
    delay var word
    'register address's
     reg_seconds        CON  $02
     reg_minutes        con  $03
     reg_hours          con  $04
     reg_days           con  $05
     reg_weekdays       con  $06
     reg_months_century con  $07
     reg_years          con  $08
     reg_minute_alarm   con  $09
     reg_hour_alarm     con  $0A
     reg_day_alarm      con  $0B
     reg_weekday_alarm  con  $0C
     rtc_write var byte
     rtc_read  var byte
     rtc_write=$a2
     rtc_read=$a3
     'time variables
     bcdseconds var BYTE
     bcdminutes var BYTE
     bcdhours  var BYTE
     bcddays  var BYTE
     bcdyears var BYTE
     seconds var BYTE
     minutes var BYTE
     hours var BYTE
     days var BYTE
     years var BYTE
      'initial time variable values
      seconds=01
      minutes=23
      hours=22
     'days=23
     'years=7
    'write intial variable's to the relevant rtc registers
    init:
    bcd_encode:
    bcdseconds=seconds dig 1
    bcdseconds=bcdseconds<<4
    bcdseconds=bcdseconds+seconds dig 0
    bcdminutes=minutes dig 1
    bcdminutes=bcdminutes<<4
    bcdminutes=bcdminutes+minutes dig 0
    bcdhours=hours dig 1
    bcdhours=bcdhours<<3
    bcdhours=bcdhours+hours dig 0
    pause 10
    I2CWrite data_pin,clk_pin,$A2,reg_seconds,[bcdseconds,bcdminutes,bcdhours]
    clock_read:
    I2CRead data_pin,clk_pin,$A3,reg_seconds,[bcdseconds,bcdminutes,bcdhours]
    pause 10
    bcd_decode:  'decodes bcd to decimal
    seconds=(bcdseconds>>4)*10+(bcdseconds & %00001111)
    minutes=(bcdminutes>>4)*10+(bcdminutes & %00001111)
    hours=(bcdhours>>3)*10+(bcdhours & %00000111)
    OUT:
    pause 20
    serout2 portc.1,16780,[" ",#hours,":", #minutes,":",#seconds]
    PORTC.0=1
    PAUSE 100
    PORTC.0=0
    goto clock_read
    Jul 2007
    does anyone have any ideas?
    when the seconds register is equal to 40, the "tens" of the hours register becomes 4 (e.g 09 then changed to 49 when seconds becomes 40) the hours "tens" then returns to its correct value once seconds is smaller than 40 again.
    here is an example, i am debugging using hyperterminal:
    hours:minutes:seconds
    9(9):22(22):38(38)
    9(9):22(22):39(39)
    49(49):22(22):40(40)
    the values in the brackets are the bcd values straight from the registers without being ran through any conversion routines, i then output them using the HEX modifier.
  1. Convert long binary number to ASCII Decimal
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 9th July 2009, 13:58
  2. How to convert binary to decimal?
    By Cabomba in forum mel PIC BASIC Pro
    Last Post: - 13th October 2007, 01:27
  3. Decimal to Binary Conversion
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2006, 14:58
  4. Binary to Decimal from ADC
    By RYTECH in forum mel PIC BASIC Pro
    Last Post: - 27th July 2005, 18:51
  5. Decimal to binary conversion
    By Demon in forum Code Examples
    Last Post: - 25th February 2005, 20:05
