yes for sure. There's many way to do that.
First of all, we will disable the PBP default configuration setting. with NOTEPAD open 16F877A.INC file in the PBP folder. It look like thisnow place a ; in front of theses linesCode:;**************************************************************** ;* 16F877.INC * ;* * ;* By : Leonard Zerman, Jeff Schmoyer * ;* Notice : Copyright (c) 2003 microEngineering Labs, Inc. * ;* All Rights Reserved * ;* Date : 11/07/03 * ;* Version : 2.45 * ;* Notes : * ;**************************************************************** NOLIST ifdef PM_USED LIST include 'M16F87x.INC' ; PM header device pic16F877, xt_osc, wdt_on, pwrt_on, lvp_off, protect_off XALL NOLIST else LIST LIST p = 16F877, r = dec, w = -302 INCLUDE "P16F877.INC" ; MPASM Header __config _XT_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF & _CP_OFF NOLIST endif LISTwill look like thisCode:device pic16F877, xt_osc, wdt_on, pwrt_on, lvp_off, protect_off __config _XT_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF & _CP_OFF
default setting are now disabled.Code:;device pic16F877, xt_osc, wdt_on, pwrt_on, lvp_off, protect_off ;__config _XT_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF & _CP_OFF
Now putting your configuration fuse into your program:
If you're using PM as assembler(wich is, as i remind, the default setting in MicroCode Studio) you'll add this line in your program header
@ DEVICE PIC16F877A, HS_OSC
If you get some compilation error it's because you're using MPASM as assembler so use the following
@ __config _HS_OSC
Everything is also well explain in this thread
I hate to say that but all the explanations are in the datasheet. Different oscillator setting, different possible oscillator speed.What do different clock speeds mean? (LP,XT,HS,RC)
In your case XT is for an crystal up to 4MHZ, HS 4MHZ & up.
