what about your hardware setting? what speed of crystal do you use? If it's higher than 4MHZ, let's say 20MHZ, you must include this line at the top of your code
DEFINE OSC 20
AND you must set your programmer to HS clock speed.
The whole code will probably looks something like that
Code:DEFINE OSC 20 TRISB.2=0 'define PORTB.2 as output start: Toggle PORTB.2 PAUSE 1000 goto start
