Lookup table syntax.....
Results 1 to 5 of 5
    Feb 2009
    Default Lookup table syntax.....
    To make my lookup tables easy to manage I use the underscore to continue
    the data in equal lengths on the next line like this:
    splashscreen:
    Lookup GLCD_y,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$01,$01,_
    $7F,$01,$01,$1C,$2A,$49,$49,$00,$1C,$22,$41,$41,$4 1,$00,$7F,$08,_
    $08,$7F,$00,$00,$7F,$0E,$10,$7F,$00,$1C,$22,$41,$4 1,$41,$22,$1C,_
    $00,$00,$3F,$40,$40,$1C,$22,$41,$41,$41,$22,$1C,$0 C,$32,$41,$41,_
    $49,$6B,$3A,$00,$07,$08,$78,$08,$0F,$00,$00,$00,$1 5,$55,$55,$55,_
    $55,$55,$40,$15,$55,$55,$55,$55,$55,$55,$55,$55,$5 5,$55,$55,$55,_
    $55,$55,$55,$55,$55,$55,$55,$55,$55,$15,$40,$55,$5 5,$55,$55,$55,_
    $15,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00],GLCDData
    However, in places where I have character data rather than bmp graphics I would prefer to work with characters like this:
    GLCDPopup:
    Lookup (Popup * 21) + GLCDy,[" Verify PM Connection Verify PC Connection Sending Data to PC Transfer Complete! Clock Set! Erase EEPROM? Are You Sure? Erasing EEPROM.... EEPROM ERASED! "],GLCDascii
    Problem is, if I try to continue data on the next line after 21 characters (display lines are 21 characters long) so it's easy to visualize messages, I get a compiler error. The underscore does not let me take up on next line....
    Is there a way to do so?
    TIA,
    TR
    Bombay, India
    You can try this
    Lookup (Popup * 21) + GLCDy, _
    [" Verify PM Connection " _
    "Verify PC Connection " _
    "Sending Data to PC " _
    "Transfer Complete! " _
    "Clock Set! " _
    "Erase EEPROM? " _
    "Are You Sure? "
    "Erasing EEPROM.... " _
    "EEPROM ERASED! "] , GLCDascii
    Feb 2009
    Hi Jerson,
    Thanks for always being helpful!
    I tried your syntax and I get:
    ERROR Line 3426: Expected ']'. (PMonitor 05-18-2009.pbp)
    after:
    It doesn't mind the one after:
    TR
    Feb 2009
    As it turns out you were close Jerson, just have to close each group with end quote then follow it with a ,_
    Compiles fine, works great! Much easier to visualize and manage.....
    GLCDPopup:
    Lookup (Popup * 21) + GLCD_y,_
    ["Verify PM Connection",_
    "Verify PC Connection ",_
    " Sending Data to PC ",_
    " Transfer Complete! ",_
    " Clock Set! ",_
    " Erase EEPROM? ",_
    " Are You Sure? ",_
    " Erasing EEPROM... ",_
    " EEPROM Erased! "],GLCDascii
    Thanks!
    TR
    Feb 2009
    Hmmm...
    The forum is truncating contiguous spaces which is not conducive to documenting actual working code
  1. Lookup table or Math?
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2008, 18:55
  2. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 11:38
  3. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  4. Need help with lookup table or direct calculation
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 11th October 2006, 19:27
  5. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
