VU Meter
Results 1 to 5 of 5
Thread: VU Meter
    Now, if I understand what you try to say, is that, your noisy alarm has strong influence on your comparator? Like changing the setpoint?
    Hi, Andre
    If I understand it right ...
    one led column (I-port C) is the meter, and the other ( j -portB) is the ref index ...
    Now, you want to catch your ref level "in flight" ... ( Porta.2 turns to low )
    1st problem...
    time before you see level and you press the button ... level has changed.
    Why not extract the MAXIMUM of the readings while button pressed ???
    2nd problem...
    time you keep the finger on the button, your ref level is changing ... ( k= i-1 in a continuous LOOP )
    Your Button must act as a OneShot for K value ! ... or see Upper
    thank you for everybody, i got the problem fixed by improving the rectifier sircuit after the op amp and before the PIC everything works good now
    Thanks again for everybody's advice
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 20:42
  2. Bicycle Speedo Meter
    By Ivan Cory in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 01:50
  3. AtoD - first attempts
    Last Post: - 23rd January 2008, 19:13
  4. PIC10F206 - What is the LOWEST Power @ Rest or Sleep
    By rixtalbert in forum mel PIC BASIC Pro
    Last Post: - 18th March 2007, 14:42
  5. Audio Level Meter
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 16th November 2006, 08:05
