multi functions button press
Results 1 to 7 of 7
    Apr 2009
    Angry multi functions button press
    i need help i wanna use 1 button to multi fonction things,ex. when i press the 1st time to swich led 1 in portb.0 2nd time swich led 2 in portb.1 so on or ,i use variables, this is my code but it doesnt work, if there another way please help
    define osc 4
    symbol led_1 = portb.0
    symbol led_2 = portb.1
    symbol led_3 = portb.2
    button var porta.0
    b0 var byte
    portb = 0
    porta.0 = 1
    count button,1000, b0
    if button = 0 then
    high led_1
    low led_1
    if button = > 0 then
    high led_2
    low led_2
    if button = ??? then
    high led_3
    low led_3
    Have you tried to read B0 variable instead?
    Does it need to have a timeout? If so, probably not a bad idea to process COUNT only when you press on your push button.
    Apr 2009
    hi mister_e im new in pbp i will try many ways and i hope someone here has a good ideas how it works ,thnks mister_e.
    May 2007
    Area 71
    You should use temporary counter like this:
    start:
    button blabalabla... click
    if a= 1 then blablabla
    etc..
    goto start:
    click:
    a=a+1
    goto start
    Quote Originally Posted by malwww View Post
    define osc 4
    button var porta.0
    b0 var byte
    portb = 0
    porta.0 = 1
    if button = 0 then
    high led_1
    low led_1
    high led_2
    low led_2
    high led_3
    low led_3
    Don't you need some ENDIF statements through the code ?
    May 2009
    USA
    You should initialize B0 to be 0 and it's best to use Select Case for this code:
    Select Case B0
    	Case 0:
    		high led_1
    		low led_1
    		B0 = B0 + 1
    	Case 1:
    		high led_2
    		low led_2
    		B0 = B0 + 1
    	Case Else
    		high led_3
    		low led_3
    		B0 = 0
    End Select
    Why is the email address verification case sensitive?
    Apr 2009
    thank you GoldStar i will try it out and i post the result.
  1. Giving power to MCU upon button press - Good Idea?
    Last Post: - 21st July 2009, 07:34
  2. Using Sleep
    Last Post: - 17th August 2008, 04:05
  3. Button press and press & hold how to ?
    By GrandPa in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2007, 03:37
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
