something similar to DEC command
Results 1 to 3 of 3
    Default something similar to DEC command
    hello all
    as i understand right, dec (on hserout) and # (on serout) writes a number sign by sign out.
    now, i am searching for something similar: a value (byte or word) that i should be able to handle it sign by sign.
    for example: 2009 as word variable named year
    byte a = 2
    byte b = 0
    byte c = 0
    byte d = 9
    how can i access it like an substring.... something like a = year[0]...?
    i mean that i saw a solution already somewhere in the forum, but i am not able to remember what i am should searching for.... :-(
    thanks for a hint
    i know it's only microcontrolling, but i like it!
    You can do it with an array.
    year var byte[4]
    year[0] = 9
    year[1] = 0
    year[2] = 0
    year[3] = 2
    Or, if it suits you, you could do:
    year var byte[2]
    year[0] = 9
    year[1] = 20
    With the second, you would save a few bytes, but you would have to add in a zero for display purposes, so I guess you would not save anything.
    You could also do it with:
    year var word
    year = 2009
    This would save you the space, and look a little cleaner.
    On the last one, if you wanted to get the digits separately, you can use:
    yeardigitone = year DIG 0 (would be 9)
    yeardigittwo = year DIG 1 (would be 0)
    etc. This will fetch the digit (DIG) specified.
    http://www.scalerobotics.com
    Quote Originally Posted by mischl View Post
    hello all
    byte a = 2
    byte b = 0
    byte c = 0
    byte d = 9
    thanks for a hint
    The DIG directive ought to work
    a = year DIG 3
    b = year DIG 2
    c = year DIG 1
    d = year DIG 0
  1. My code for TV remote and MIBAM for RGB control
    By idtat in forum Code Examples
    Last Post: - 12th January 2013, 21:52
  2. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  3. LCDout $FE,2, dec Days - What is dec ?
    By merc07 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2009, 05:03
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 19:57
  5. Interupts and Command string
    By Tissy in forum Serial
    Last Post: - 18th March 2006, 00:59
