Advanced Arrays
Results 1 to 3 of 3
Thread: Advanced Arrays
    May 2009
    USA
    Default Advanced Arrays
    I'm a bit confused about arrays, I'm trying to initialize an array at runtime from saved EEPROM data, but I don't really understand how to edit what I need.
    Users		var word[10]
    Here is my array of users, but PBP won't let me
    Users[10].bit0 = 0 (syntax not supported)
    However
    Users.bit0 = 0
    compiles fine. And
    Users.byte3 = 0
    does not. Is there any easy way I can access each byte of the Users array within a for loop? If all else fails I could rewrite it using this http://www.picbasic.co.uk/forum/showthread.php?t=2444 but It'd be nice to see what the compiler is up to
    Why is the email address verification case sensitive?
    May 2009
    USA
    It seems that everything is explained here and google is a much better search engine than vBulletin apparently
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    For i = 0 to 19
    	read i, Users.Lowbyte(i)
    Next i
    Compiles without a problem, I'm hoping that this will load the first 20 EEPROM bytes into the 10 words I have, correct?
    sinoteq's Avatar
    sinoteq Guest
    Default Faq
    Hi
    If you dig deep enough in the FAQ section by selecting "Show all threads from the beginning" you will find a Melanie artwork called Bits, Bytes Words and Arrays. Or you click here http://www.picbasic.co.uk/forum/showthread.php?t=544
    This will give you all the answers you'll need for accessing an array and other neat tricks that will come in handy later in life.
    Last Post: - 14th June 2016, 08:55
  2. Beginner trying to use arrays
    By captain in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2007, 08:20
  3. SerOut and Arrays
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 4th July 2005, 18:32
  4. word arrays and eeprom
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 9th January 2005, 08:36
  5. storing arrays and reading arrays
    By Yue in forum mel PIC BASIC Pro
    Last Post: - 5th March 2004, 23:03
