Pir Sensor
Results 1 to 5 of 5
Thread: Pir Sensor
    Feb 2007
    Malaysia
    Default Pir Sensor
    I need sample code to read value from PIR Sensor.
    Can somebody please help.
    Dec 2007
    Finland
    Post
    Some more info would be useful (spec, etc...)
    - Analog or digital output?
    BR,
    -Gusse-
    Feb 2007
    Malaysia
    Hi Gusse,
    The output is digital.
    Thanks for reply.
    Aug 2005
    down south
    I use a lot of PIR's with my motion activated camera's they put out a high 5volts when tripped I add a pull down resister and treat it a like a reg. input
    if pir= 1 then do what ever
    hope this helps
    " be nice it's people like me that make people like you look smart"
    yes I read the datasheet, of the 300 pages I understood 10
    Feb 2007
    Malaysia
    thanks Grounded.
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Ultrasonic distance sensor with PIC16F84A
    Last Post: - 29th June 2009, 10:01
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  4. Replies: 6
    Last Post: - 18th January 2008, 09:17
  5. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 16:55
