Which is the best way to connect..
Results 1 to 5 of 5
    dtit's Avatar
    dtit Guest
    Default Which is the best way to connect..
    pi2pic when they are on same PCB and using two pins to communicate between them, and have one executing a task when reciving a message from the other pic.
    ex. 16F877->16F628
    message something like "do your B.0=1, B.1=1,value=168"
    which method should a use, there are so many, read so much that it just confusing me more and more.
    Italy
    Connect two Basic Stamps together in a Master-Slave arrangement.
    Best regards,
    Luciano
    Nuts and Volts Magazine
    Column #81, January 2002 by Jon Williams:
    - - A Tale of Two Stamps - -
    PDF file:
    http://www.parallax.com/dl/docs/cols...3/col/nv81.pdf
    Project code:
    http://www.parallax.com/html_pages/d...wnloads_V3.asp
    Both have internal USART. Connect TX from F628 to RX of F877, RX from F628 and TX of F877 together.
    After that you can send a kinda *formated message* . something like that.
    F628:
    HSEROUT [Var1,Var2,Var3]
    F877:
    HSERIN [Var1,Var2,Var3]
    Every VAR can be a specific task. You'll have to play with them with some IF THEN or SELECT CASE.
    Italy
    Works also without USARTs. See my post with the example for Basic Stamp 2.
    The Basic Stamp 2 commands "Serin" and "Serout" are similar to
    the PicBasic Pro "Serin2" and "Serout2" commands.
    (One optional pin is used for the flow control).
    Luciano
    dtit's Avatar
    dtit Guest
    Default tanx a lot guys..
    I have some new things to test know
  1. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  2. Haw to connect two pic?
    By edysan in forum Serial
    Last Post: - 24th August 2007, 08:45
  3. how can i connect the speaker
    By pcbb in forum mel PIC BASIC Pro
    Last Post: - 7th April 2007, 19:28
  4. How to connect PIC16F84A to mobile phone
    By PoTeToJB in forum Schematics
    Last Post: - 8th March 2006, 16:32
  5. XPort or Connect Me help???
    By ccsparky in forum mel PIC BASIC Pro
    Last Post: - 26th November 2005, 17:37
