MPXA4115A picbasic code
Results 1 to 40 of 104
    Unhappy
    Hi, Alex
    Interrupts ... ok, nice idea, ... but it will surely interfere with your INPUT Pulsin ....
    hé,hé ... you said " Aaaargh !!! " ???
    If you go to interrupts, you will not need any pulsin, or pulsout. There are a couple ways to input multiple channels for pulse width measurement. You could either make an interrupt on change on GPIO port, then poll the pins for change, or ....
    tie both outputs of the receiver together, and connect them to the CPP1 pin. Only one will pulse at a time (on most rc receivers), so you will be able to read one at a time, even though they are connected together.
    One thing I am not sure about is if there is enough time between pulses to read adjacent channels. Have not tried that yet. But channels that are separated by one channel, like 1 and 3, etc would be easy. Hard part would be telling channels from each other. For this, you could place an input on one of the in between channels to mark which pulse width you would be measuring next.
    Or, make a multiplexing switch that switches between the throttle, and the on/off switch, and have those go to the same CCP1 pin.
    Talking
    If you want to give a try ...
    with " classical " receivers ( CMOS 4015/4017/HC164/NE5045 decoders ) you have ...
    15 ns ... as a " mark pulse " ...
    Jan 2004
    Thessaloniki , GREECE
    ... or maybe using HPWM for pulsout ? to keep SC alive all the time!
    Wink
    Hi, Alex
    I spent some more time on your code ...
    should work as I verified the timing and flow with MPSIM ...
    ' (c)2009 Alexandros Zahariadis (E.A.TH.) Greece *
    ' Electric Glider electronic switch to be used in F3J-GR competitions.
    ' The device will cut-off motor if 200m ALT reached or 30seconds passed
    ' whichever comes first!
    ' There is also a status led option which idicates if you have reached 200m
    ' or not (may be because of luck of power!)
    ' steady led -> 200m ALT reached , blinking led -> 30 secs passed.
    ' NOTE: after a lot of experiments and because of code execution speed
    ' I use direct ADC raw sample values without converting them to meters first!
    '    :: thanks to Acetronics (Alain) and picbasic forum for codding ideas ::
    '@ DEVICE FCMEN_OFF
    '@ DEVICE IESO_OFF
    '@ DEVICE BOD_ON
    '@ DEVICE CPD_OFF
    '@ DEVICE PROTECT_OFF
    '@ DEVICE MCLR_OFF
    '@ DEVICE PWRT_OFF
    '@ DEVICE WDT_OFF
    '@ DEVICE INTRC_OSC
    @    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _BOD_ON
    INCLUDE "modedefs.bas"
    DEFINE PULSIN_MAX 2500
    ;DEFINE DEBUG_REG GPIO
    ;DEFINE DEBUG_BIT 2
    ;DEFINE DEBUG_BAUD 9600
    ;DEFINE DEBUG_MODE 1
    OSCCON = $60            ' $60:4 Mhz $70:8 Mhz int.
    CMCON0 = 7              'TURN COMPARATORS OFF
    TRISIO = %00001010      'Set GPIO1 and GPIO3 0 INPUTS, others to OUTPUT
    ANSEL =  %00000100      'Set AN2 , Fosc/32
    ADCON0 = %00000000      'AN2 select & Right Justify for 10-bit
    THROTTLE    VAR GPIO.0  'Outputs to throttle servo
    RADIO       VAR GPIO.1  'Input from receiver
    LED         VAR GPIO.2  'status indicator
    ADC_DATA	VAR	GPIO.3	' adc serial data
    ADC_SCLK    VAR	GPIO.5	' adc serial clock
    ADC_CS		VAR	GPIO.4	' adc chip select
    advalue 	VAR	word    ' value read from adc
    groundALT   VAR word
    difalt      VAR word
    P           VAR WORD    ' This stores the PULSIN value
    x           VAR byte    ' general var
    y           VAR byte    ' general var
    Dummy       VAR word
    SEC_COUNT   VAR BYTE    ' seconds counter
    O_FLOWS     VAR BYTE    ' holds the number of timer1 overflows
    BRAKE_PULSE VAR word    ' servo pulse to STOP (brake on) THR servo
    CLEAR
    'BRAKE_PULSE = 100
    '-= vars for averaging routine =-
    AvgCount	CON  6		' = Number of samples to average
    FAspread	CON  1000	' = Fast Average threshold +/-
    Value		VAR  WORD
    '-= end of vars for averaging routine =-
    ' TIMER1 Cycle MUST be longer than a R/C frame duration to be sure not to miss any ticks.
    ' 50 ms is a good value for timing precision.
    ' PL = 15543 @ 4Mhz ( reload = 7 cycle )
    T1LO CON $49            'timer1 preload values
    T1HI CON $C3            '$C349 -> -15543
    LOW throttle
       INTCON  = 0          ' disable interrupts
       T1CON = %00010000    ' 1:2 prescale (1uS per tick), timer1 off (max 1:8!)
                            ' 11 = 1:8 ,10 = 1:4, 01 = 1:2, 00 = 1:1 Prescale Value
       TMR1H = T1HI         ' 65,536-15536 = 50.000
       TMR1L = T1LO         ' 50.000 ticks * 1uS =50.000usec.=100msec
                            ' 1 second= 100*10
                            ' every 10 timer1 overflows = 1 second   1uS=
    pause 3'000
    for x=1 to 4
    	high led
    	pause 2'00
    	low led
    	pause 1'00
    next x
    CAL_BP: ' CALIBRATING Brake_Pulse ( P )
    		' Controller must see Brake Pulse to Unlock ...
    	Pause 50
    	LOW led
     	Brake_Pulse = 0
    	For x = 1 TO 16
    		PULSIN radio,1,P
    		IF ( P < 80 ) OR ( P > 220 ) Then
    			Led = 1
    			GoTo CAL_BP
    		EndIF
    		IF Brake_Pulse = $00 Then prems
    		IF ( P < (Brake_Pulse -1)) OR ( P > (Brake_Pulse +1)) THEN
    			Led = 1
    			GoTo CAL_BP
    prems:	Brake_Pulse = P
    	Next x
    LOW Throttle
    precheck:            'leave some seconds to do a motor test
    					 'then motor brake is ON for some seconds
    for y=1 to 3
    	for x=1 to 255
    		PULSIN RADIO,1,P
    			Led = 1
    			GoTo Precheck
    		EndIF
    		Led = 0
    		LOW Throttle
    		PULSOUT THROTTLE, p
    	next x
    next y
    ' GroundAlt measure : Motor is Locked, But Brake_Pulse lenght must be sent ...
    for x=1 to 160								'160 x 22ms =
    	LOW Throttle
    	PULSOUT THROTTLE, brake_pulse
    	pause 19
    next x
    low THROTTLE
    GOSUB GetAdc         						'Get ground ALT
    groundalt = value
    armcheck: '20.9 ms						' Now, we can launch the beast ...
    PULSIN RADIO,1,P
    		Led = 1								' Show Problem !!!
    		LOW Throttle
    		PULSOUT THROTTLE, brake_pulse		' Not to lock Controller
    		GoTo Armcheck
    Led = 0
    low throttle
    PULSOUT THROTTLE, p
    GOSUB GetAdc         						'Get ALT
    if difalt < 2 OR difalt > 10000 then Armcheck 'Arm if>=5mALT (in adc samples) reached!!
    start:                  				' We are flying , now ... preset timer1
       SEC_COUNT=28         				' load for 30 to 0 seconds countdown
       O_FLOWS=0            				' clear overflow count
       PIR1.0=0             				' clear timer1 overflow flag
       T1CON.0=1            				' start timer1
    low throttle							' to be sure ...
    gosub GetADC
    PULSIN RADIO,1,P
    pauseUS 10
    pULSOUT THROTTLE, p
    ' Note: Timer1 overflows every 0.050 seconds
       IF PIR1.0 THEN           			' if timer1 overflow then
          O_FLOWS = O_FLOWS + 1     		' inc oveflow counter
          IF O_FLOWS = 20 THEN    			' if 1 second elapsed
    	      SEC_COUNT = SEC_COUNT - 1 	' decrement seconds count
    	      O_FLOWS=0             		' reset overflow counter
          T1CON.0 = 0           			' stop timer1
          TMR1H = T1HI 						' Reload values
          TMR1L = T1LO
          T1CON.0=1              			' re-start timer1
    if difalt>=89 and difalt<10000 then KILL_MOTOR_ALT 'Check if 100mALT
                                                       '(in adc samples) reached!!
    if sec_count < 1 then KILL_MOTOR_TMR
    '                                SUBROUTINES
    GetADC:	'Read MAX187 12bit ADC value - Take 9.25 ms
    low ADC_CS
    PAUSEUS 10
    Average:' -=-=-=-=-=-=  Average 16 X Analog values -=-=-=-=-=-=-=-=-=-=
      For x = 0 to 15			' 16 Samples MAXI !!!
      shiftin ADC_DATA,ADC_SCLK,msbpost,[advalue\12]	'337 µs
      value = value + advalue
      PAUSEUS 200
      NEXT x
      Value = Value / 16
    difalt = groundalt - value
    high ADC_CS
    KILL_MOTOR_ALT:
    low throttle
    high led
    LOOP1:
    PULSOUT throttle, brake_pulse   ' Kill motor - adjust this value. 4Mhz ->> 10uSec
    pause 19
    goto LOOP1
    KILL_MOTOR_TMR:
    x 		= 0
    T1CON.0 = 0						' Stop the Timer
    LOOP2:
    low throttle
    IF X = 0  THEN led = led ^ 1
    x = ( x+1 ) // 18							' Counter for led Blinking @ 1.5 Hz
    pause 19
    goto LOOP2
    Fond some " strange " things and corrected them ...
    Jan 2004
    (SO....I have to see both codes side by side so I can learn for my mistakes )
    You 've done excellent coding ...I'll give it a try although I had problems with averaging routines -keep sending '0' as result!
    I agree with Walter.
    All this "Software Timed" stuff just doesn't work well together.
    Everything, should be Interrupt driven.
    Capture (CCP) the received pulses.
    Use A/D interrupt to OverSample the Altitude. (oversampling does not have to be "Blocking")
    Timer interrupt to drive the servo.
    No PULSIN's, no PULSOUT's, no SHIFTIN/OUT.
    These PIC chips are extremely fast. (As long as the program isn't sitting in a loop somewhere waisting 90% of it's time.)
    And with the Hardware doing most of the work, they "Scream".
    Even if you don't use Interrupts ... Use the hardware.
    By itsssyam in forum General
    Last Post: - 10th March 2010, 06:01
    Last Post: - 7th December 2008, 14:17
    Last Post: - 15th April 2007, 18:31
    Last Post: - 30th May 2006, 22:50
  5. PicBasic Fundamentals
    By Billyc in forum General
    Last Post: - 4th May 2004, 10:04
