Hi Alexandros
I had committed that from what you wrote ...
' (c)2009 Alexandros Zahariadis (E.A.TH.) Greece *
' Electric Glider electronic switch to be used in F3J-GR competitions.
' The device will cut-off motor if 200m ALT reached or 30seconds passed
' whichever comes first!
' There is also a status led option which idicates if you have reached 200m
' or not (may be because of luck of power!)
' steady led -> 200m ALT reached , blinking led -> 30 secs passed.
' NOTE: after a lot of experiments and because of code execution speed
' I use direct ADC raw sample values without converting them to meters first!
'    :: thanks to Acetronics (Alain) and picbasic forum for codding ideas ::
'@ DEVICE FCMEN_OFF
'@ DEVICE IESO_OFF
'@ DEVICE BOD_ON
'@ DEVICE CPD_OFF
'@ DEVICE PROTECT_OFF
'@ DEVICE MCLR_OFF
'@ DEVICE PWRT_OFF
'@ DEVICE WDT_OFF
'@ DEVICE INTRC_OSC
@    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _BOD_ON
INCLUDE "modedefs.bas"
clear
define PULSIN_MAX 250
;DEFINE DEBUG_REG GPIO
;DEFINE DEBUG_BIT 2
;DEFINE DEBUG_BAUD 9600
;DEFINE DEBUG_MODE 1
OSCCON = $60           ' $60:4 Mhz $70:8 Mhz int.
CMCON0 = 7              'TURN COMPARATORS OFF
TRISIO = %00001010      'Set GPIO1 and GPIO3 0 INPUTS, others to OUTPUT
ANSEL =  %00000100      'Set AN2 , Fosc/32
ADCON0 = %00000000      'AN2 select & Right Justify for 10-bit
THROTTLE    VAR GPIO.0  'Outputs to throttle servo
RADIO       VAR GPIO.1  'Input from receiver
LED         var GPIO.2  'status indicator
ADC_DATA	var	GPIO.3	' adc serial data
ADC_SCLK    var	GPIO.5	' adc serial clock
ADC_CS		var	GPIO.4	' adc chip select
advalue 	var	word    ' value read from adc
groundALT   var word
difalt      var word
P           VAR WORD    ' This stores the PULSIN value
x           var byte    ' general var
y           var byte    ' general var
SEC_COUNT   VAR BYTE    ' seconds counter
O_FLOWS     VAR BYTE    ' holds the number of timer1 overflows
BRAKE_PULSE var word    ' servo pulse to STOP (brake on) THR servo
BRAKE_PULSE = 100
'-= vars for averaging routine =-
AvgCount	CON  6		' = Number of samples to average
FAspread	CON  1000	' = Fast Average threshold +/-
Value		VAR  WORD
'-= end of vars for averaging routine =-
' TIMER1 Cycle MUST be longer than a R/C frame duration to be sure not to miss any ticks.
' 50 ms is a good value for timing precision.
' PL = 15543 @ 4Mhz ( reload = 7 cycle )
T1LO CON $49            'timer1 preload values
T1HI CON $C3            '$C349 -> -15543
low throttle
   INTCON  = 0          ' disable interrupts
   T1CON = %00010000    ' 1:2 prescale (1uS per tick), timer1 off (max 1:8!)
                        ' 11 = 1:8 ,10 = 1:4, 01 = 1:2, 00 = 1:1 Prescale Value
   TMR1H = T1HI         ' 65,536-15536 = 50.000
   TMR1L = T1LO         ' 50.000 ticks * 1uS =50.000usec.=100msec
                        ' 1 second= 100*10
                        ' every 10 timer1 overflows = 1 second   1uS=
pause 3000
for x=1 to 4
	high led
	pause 200
	low led
next x
CAL_BP: ' CALIBRATING Brake_Pulse ( P )
	Pause 50
	LOW led
 	P = 0
	For x = 1 TO 16
		PulsIn radio,1,P
		IF ( P < 80 ) OR ( P > 220 ) Then
			Led = 1
			GoTo CAL_BP
		EndIF
		IF P = $00 Then prems
		IF ( P < (Brake_Pulse -1)) OR ( P > (Brake_Pulse +1)) THEN
			Led = 1
			GoTo CAL_BP
prems:	Brake_Pulse = P
	Next x
LOW Throttle
'calibrate:             'check for valid signal
'For x = 1 TO 2
'	PulsIn radio,1,P
'	pauseus 10
'	IF ( P < 80 ) OR ( P > 200 ) Then calibrate
'	next x
'for x=1 to 3
'	PulsIn radio,1,P
'	brake_pulse = P
'next x
'low led
'low throttle
precheck:            'leave some seconds to do a motor test
						'then motor brake is ON for some seconds
for y=1 to 3
	for x=1 to 255
		PULSIN RADIO,1,P
			Led = 1
			GoTo Precheck
		EndIF
		Led = 0
		LOW Throttle
		pULSOUT THROTTLE, p
	next x
next y
for x=1 to 160
	LOW Throttle
	PULSOUT THROTTLE, brake_pulse
	pause 18
next x
low THROTTLE
GOSUB GetAdc         						'Get ground ALT
groundalt=value
armcheck:									' Now, we can launch the beast ...
PULSIN RADIO,1,P
		Led = 1								' Show Problem !!!
		LOW Throttle
		GoTo Armcheck
Led = 0
low throttle
PULSOUT THROTTLE, p
if difalt < 2 OR difalt > 10000 then Armcheck 'Arm if>=5mALT (in adc samples) reached!!
start:                  				' We are flying , now ... preset timer1
   SEC_COUNT=28         				' load for 30 to 0 seconds countdown
   O_FLOWS=0            				' clear overflow count
   PIR1.0=0             				' clear timer1 overflow flag
   T1CON.0=1            				' start timer1
low throttle							' to be sure ...
gosub GetADC
PULSIN RADIO,1,P
pauseUS 10
pULSOUT THROTTLE, p
' Note: Timer1 overflows every 0.050 seconds
   IF PIR1.0 THEN           			' if timer1 overflow then
      O_FLOWS = O_FLOWS + 1     		' inc oveflow counter
      IF O_FLOWS = 20 THEN    			' if 1 second elapsed
	      SEC_COUNT = SEC_COUNT - 1 	' decrement seconds count
	      O_FLOWS=0             		' reset overflow counter
      T1CON.0 = 0           			' stop timer1
      TMR1H = T1HI 						' Reload values
      TMR1L = T1LO
      T1CON.0=1              			' re-start timer1
if difalt>=89 and difalt<10000 then KILL_MOTOR_ALT 'Check if 100mALT
                                                   '(in adc samples) reached!!
if sec_count<=0 then KILL_MOTOR_TMR
'                                SUBROUTINES
GetADC:									'Read MAX187 12bit ADC value
low ADC_CS
PAUSEUS 10
shiftin ADC_DATA,ADC_SCLK,msbpost,[advalue\12]
high ADC_CS
Average:' -=-=-=-=-=-=  Average 6 X Analog values -=-=-=-=-=-=-=-=-=-=
    IF Value = advalue Then NoChange
    IF ABS (Value - advalue) > FAspread OR Value < AvgCount Then FastAvg
    IF ABS (Value - advalue) < AvgCount Then RealClose
    advalue = advalue - (advalue/AvgCount)
    advalue = advalue + (Value/AvgCount)
    GoTo AVGok
FastAvg:
    advalue = Value
    GoTo AVGok
RealClose:'If averaging more than 8 samples,change to (AvgCount/4)
    advalue = advalue - (advalue/(AvgCount/2))
    advalue = advalue + (Value/(AvgCount/2))
AVGok:
    Value = advalue					' Put Average back into Value
NoChange:' -=-=-=-=-=-=  End of Averageing -=-=-=-=-=-=-=-=-=-=
difalt=value-groundalt
KILL_MOTOR_ALT:
low throttle
high led
LOOP1:
PULSOUT throttle, brake_pulse   ; Kill motor - adjust this value. 4Mhz ->> 10uSec
pause 18
goto LOOP1
KILL_MOTOR_TMR:
x = 0
LOOP2:
low throttle
IF X = 0  THEN led = led ^ 1
x = ( x+1 ) // 18							' Counter for led Blinking @ 1.5 Hz
pause 18
goto LOOP2
But did not try it ...
have fun
