MPXA4115A picbasic code
Results 1 to 40 of 104
Threaded View
  1. #13
    Jan 2004
    Thessaloniki , GREECE
    3d visualization of a test pcb attached...
    As you notice I didn't care much about the placement of sensor caps.
    Just wanted to see the size of the board and best placement of connectors
    (pcb measured... 45mm X 30 mm)
    PLEASE NOTE all connectors will be male (not as seen) except for the sensor that it will be soldered on board
    The sensor will be layed above C3 C2 and C1 (low profile cap)
    By itsssyam in forum General
    Last Post: - 10th March 2010, 06:01
    Last Post: - 7th December 2008, 14:17
    Last Post: - 15th April 2007, 18:31
    Last Post: - 30th May 2006, 22:50
  5. PicBasic Fundamentals
    By Billyc in forum General
    Last Post: - 4th May 2004, 10:04
