MPXA4115A picbasic code
Results 1 to 40 of 104
    Quote Originally Posted by iw2fvo View Post
    I have in mind to put the PIC ADC " -REF " to 3.75 Vdc and the ADC " +REF" to 5Vdc.
    The maximum VREF- is (VREF+ -2.0V). So with VREF+ at 5V, VREF- can be 3.0V MAX.
    I'll add the option to the calculator later tonight and see what happens.
    Jun 2008
    Varese , Italy
    Thanks Darrel,
    I forgot the vref- constrain. So the VREF- will be 3Vdc.
    Ambrogio
    You're welcome Ambrogio,
    I've added the Vref+/- to the calculator.
    It should come up with a good formula for you now.
    I haven't figured out how to deal with the +/-1.8% error yet.
    So these numbers represent an "Ideal" sensor.
    MPX4115A Calculator
    http://www.pbpgroup.com/Calculators/...A/MPX4115A.htm
    Now I gotta go back and redo the MPX4250D for Walter.
    hth,
    Wink
    Hi, Darrel
    Handy tool, indeed !
    Could you add ( or allow ) the 4.096, 2.56, 2.048 and 1.024v "Classical" Vref values ( 3 decimals !!! ) ???
    Done.
    MPX4115A Calculator
    Hit refresh if you already have the page open.
    Jun 2008
    Varese , Italy
    Darrel,
    it is a very usefull calculator: thanks again.
    I will use a 5Vdc Vref+ and a divide by resistor divider for Vref-. Could it be OK ?
    Is there any possibility to compensate for the accuracy error ?
    ( I am not familiar with those sensors .. ).
    regards,
    Ambrogio
    IW2FVO
    North Italy
    Resistors will work fine.
    It's difficult to get exactly 3.0V using standard values, but with a 4.7K and 6.8K divider, you'll get about 2.96V. Use 1% or better resistors.
    These pressure sensors are "Ratiometric" which means that their output voltage changes proportionally to the power supply voltage. So using resistors allows the Vref to change with the power supply voltage too, which is a good thing. A voltage reference that does not change with PS differences can cause incorrect readings if VDD is not exactly 5.00V. Many 7805 type regulators will be anywhere from 4.85 to 5.15V
    For the accuracy, each sensor will be off by a different amount up to 1.8% of full scale.
    You would need to take readings from the sensor being used at both the high and low ends of the range, and compare them against values read by some other device that is known to be calibrated.
    The slope and intercept can then be recalculated for the measured values to create a new formula for that specific sensor. The calculations can be done with the PIC, but I wouldn't recommend it. Or you can do the calculation manually and just enter the slope and intercept into the PIC for that specific sensor.
    By itsssyam in forum General
    Last Post: - 10th March 2010, 06:01
    Last Post: - 7th December 2008, 14:17
    Last Post: - 15th April 2007, 18:31
    Last Post: - 30th May 2006, 22:50
  5. PicBasic Fundamentals
    By Billyc in forum General
    Last Post: - 4th May 2004, 10:04
