11lc160 1 wire eeprom
Results 1 to 4 of 4
    Default 11lc160 1 wire eeprom
    11LC160 1 wire eeprom
    Has anyone used one of these successfully ?
    Looks as if it's not going to use OWIN/OWOUT, maybe pulseout.
    Done it awhile back, but rolled my own routine, not sure for which model though as I lost it (oh long story here).
    Did you checked AN1174 from Microchip and their code?
    http://www.microchip.com/stellent/id...pnote=en535470
    Do you have them on hand?
    Hi Steve,
    Yeah, I got 2 samples a while back, I saw some of what's in the apnote when I ordered them but have only seen the data sheet since, the AN1174 has more useful stuff than the data sheet, useful if I were a savy assembly programmer that is. I will fumble around with what they got in there. It looks like you can chain up a bunch of them and access individually.
    JS
    You shouldn't have so much problem doing the code in PBP. It's all there, for once they made a really complete AppNote.
    If you have a PICKIT 2, you could program/read them to confirm your code work as suppose to... not to mention the logic analyser
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
