Hi and welcome aboard
Knowing the "frequency range" and the PIC you're going to use would help. However in some circumstance, PBP COUNT command could do the job.
You could do a search for Frequency Counter or simply Counter with the forum search tool. Sure enough there's a load of tips and example here that might help you.
I used it (count) for a tachometer and it was fast enough. http://www.picbasic.co.uk/forum/showthread.php?t=9037
Alter the math a bit, based upon the wheel diameter and you have it. this is set up for an LED display, LCD would use less code.
