Ok, so using the calc I get PR2 = 9, duty register = 20 and with a 1:1 prescaler.
Is this about right?:
Code:OSCCON = $70 define osc 8 CSET VAR WORD 'CURRENT SET CSEN VAR WORD 'CURRENT SENCE DUTY VAR wORD 'HPWM DUTY CYCLE ADCON0 = %00011001 ADCON1 = %00001111 ADCON2 = %10111111 TRISA = %00000000 TRISB = %00110011 Define ADC_BITS 10 ' Set number of bits in result Define ADC_CLOCK 3 ' Set clock source (3=rc) Define ADC_SAMPLEUS 10 ' Set sampling time in uS 'DUTY = 30 'SET INITIAL OUTPUT CURRENT HIGH TO ENABLE FAST STARTUP CSET = 0 CSEN = 0 duty = 20 ' duty value for 50% duty cycle PR2 = 9 ' T2CON = %00000100 ' timer2 on, prescale 1:1 CCPR1L = duty>>2 ' MSB of duty cycle value CCP1CON=%00001100 | (dUTY<<5) ' set PWM mode and store the ' 2 LSB of duty LOOP: ADCIN 6, CSET 'READ VALUE OF CURRENT SET POT ADCIN 4, CSEN 'READ VALUE OF CURRENT SENCE IF CSEN > CSET THEN LET DUTY = DUTY - 1 IF CSEN < CSET THEN LET DUTY = DUTY + 1 CCPR1L = duty>>2 ' MSB of duty cycle value CCP1CON=%00001100 | (dUTY<<5) ' set PWM mode and store the ' 2 LSB of duty 'HPWM 1,DUTY,32767 'OUTPUTS THE DUTYCYCLE AT 32.767KhZ GOTO LOOP
