fuel flow sensor?
Results 1 to 18 of 18
    Nov 2004
    Calabasas, CA
    Default fuel flow sensor?
    I want to make a mpg display for an older vehicle with carburation. Any sources for getting a fuel flow sensor?
    James
    James
    Mar 2009
    Florida USA
    Default fuel sensors...
    Hi James,
    there are some finished fuel meter available (some are made for boat engines).
    Sensors for gas are not found easily, check McMillan www.mcmflow.com , they have what you need but not inexpensive. Does your old car have a gas return line (carburator to tank)?
    Nov 2004
    Calabasas, CA
    Quote Originally Posted by misterg View Post
    Hi James,
    Thanks for the reply. McMillan is USD$200, a little pricey for what I was looking for. No return lines for gravity feed older fuel systems.
    James
    California, USA
    Once apon a time (late 80's?) certain models of Ford cars with carburetors had an external fuel flow sensor in line with carburetor. The sensor was used for a onboard gas mileage calculator...
    I had a GF years ago who had a Ford Capri (I think it was a Capri) with the 2.6L V6 and it had the mileage calculator and fuel flow sensor.
    Maybe you could still score one at the auto parts store or wrecking yard.
    Nov 2004
    Calabasas, CA
    Quote Originally Posted by Byte_Butcher View Post
    Good lead, didn't know that. I will pursue.
    James
    Dec 2007
    Finland
    Post
    At least Conrad.de sell fuel meters at reasonable price.
    Here is one example of fuel meter circuit: Fuel Meter by Possi
    Used fuel meter: Fuel meter (DURCHFLUSS-IMPULSGEBER INDUKTIV POM) (in German)
    I hope this will help you. I have my own plans to make fuel meter too. Still under planning stage...
    BR,
    -Gusse-
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Fuel consumption display
    By veijavi in forum mel PIC BASIC Pro
    Last Post: - 27th December 2011, 07:05
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  4. Mass Air Flow Sensor Data
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 1st January 2009, 10:35
  5. hot water flow sensor
    By jessey in forum Off Topic
    Last Post: - 24th January 2007, 05:05
