HSERIN and XOUT command
Results 1 to 21 of 21
    I did try your suggestion without any luck.
    Did you also change the RX handler to receive only 1 byte at a time? Waiting for a whole string takes a LONG time.
    And, have you tried the XIN without the interrupts? Is XIN working at all?
    You can add a Timeout to XIN, in case it's not receiving anything.
    Is the XIN supposed to be running continuously in a loop, or as a response to the 250 command?
    If it was in response to the command, it's more likely that incoming data will not occur again in the middle of the XIN.
    May 2008
    Italy
    Yes I did But it doesn't work very well. A command must be sent twice or three times to be executed, while with the whole string method commands are all decoded and executed correctly at the first time. Very likely my code is not so efficient as the whole string.
    Here the code used: (Where : RxBuffer VAR PIR1.5)
    Getbytes:
    A0=0
    While RxBuffer=1
    Hserin 100,ErrorFlag,[Rdata[A0]]
    A0=A0+1
    Wend
    @ INT_RETURN
    Yes with "SERIN2/SEROUT2" did work, not with "HSERIN/HSEROUT". But as you can understand, I need to jump out from Xin loop when an X10 command is received via Xbee in order to service it with the Xout command.
    Xin is supposed to continuouly scan the main for X10 commands coming in from the different sources capable to issue such a command. The incoming data will be used to update a memory area containing the status of various lamps and appliances (On/Off).
    Al.
    how about get rid of the timeout label and the IF-THEN?
    Dec 2005
    As written, Xin is blocking. You need a timeout and jump_to_label.
    May 2008
    Italy
    Steve, are you refering to the code in my post#11?
    dhoston, Xin is blocking the USART with and without the timeout
    Al.
    yes I do (and so Darrel @ post #8). Anyway, if you jump to that ISR... your buffer already hold something.. so there's no real advantage to the Timeout, then no advantage to whatch PIR1 either. You get the character, you get out of there as fast as possible, if there's a second character, you'll be redirected over there shortly.
    That Is easy to do that in asm. So it will be faster again, and give you less latency in XOUT... so probably solve most part of the problem.
    You could still get rid of HSERIN and read RCREG directly.
    May 2008
    Italy
    Steve, in this case I must change sligthly the Tx string, adding a terminator character.
    The code as it is, using "Hserin 100,ErrorFlag,[str Rdata\9]" works perfectly and Xout do the job.
    I have got away from the trouble when I did remove the "XIN" command.
    I am sure that XIN and Hserin/Hserout are not compatible for unknown (so far) reasons.
    Since I need also the XIN, I am putting togheter a second prototype with two pics on board, so I will separate XIN/SEROUT2 commands, from Hserin/XOUT (Hardware solution to the problem)
    Al.
    Dec 2005
    Quote Originally Posted by aratti View Post
    Loop:
    xin X10Rx,ZCrox,[Housekey]
    hSerout ["H: ",#Housekey.byte1,13,10]
    hserout ["K: ",#Housekey.byte0,13,10]
    goto loop
    Your XIN will wait forever for an input. You can add a timeout and label to XIN but it does not solve the problem.
    PBP is not a good choice for doing X10 because of this. You either need a dedicated loop that does nothing but wait for X10 input or risk missing the X10 input. Unless you can write a interrupt routine to check for input 500µS after each ZC you should look for another solution.
    As it happens, I am currently working with the creater of ZBasic to refine its X10 functions. It does X10 input and output in the background automatically, including collision avoidance. The refined version should be available in a couple of weeks.
    The smallest ZBasic chip costs $10 but may not have enough program memory for you. I haven't really analyzed your code.
    ZBasic uses Atmel AVR chips. It has a serial bootloader and a free IDE/compiler. It has a hardware UART and up to 4 full-duplex, interrupt driven, software UARTs that operate in the background. It also has many other features but the smallest chip is 28-pins. http://www.zbasic.net/
    Dec 2005
    Smile Ooops!
    ZBasic does collision avoidance in the application I am working on. It cannot do collision avoidance with the TW523 (and clones) as the TW523 X10 outputs are delayed 22 ZC cycles and any detected collisions have already occured - only Dr. Who could avoid them. But we can detect them with the TW523.
