HSERIN and XOUT command
Results 1 to 21 of 21
    Hi Aratti,
    This could be a problem.
    In the Main loop, actually Loop:, there is an XIN statement that runs on every loop. Then if you receive data in the interrupt handler, the TxCommand is called which does an XOUT. The XOUT could potentially be triggered in the middle of the XIN. Possibly leaving XIN waiting for something it will never receive.
    That could keep the HSEROUT's from being executed.
    If you set a "flag" in the interrupt handler when it receives data, then do the XOUT in the main loop when it sees the flag, it won't try to do both XIN and XOUT at the same time.
    Added: You may also need to have the RX interrupt receive bytes 1 at a time instead of a full string, to keep it from interfereing with the XIN to begin with.
    hth,
    May 2008
    Italy
    Default No luck
    Hi Darell, thank you for your answer. I did try your suggestion without any luck.
    In doing these changes I came to the conclusion that Xin command is the problem, infact simply removing Xin from the code and Txing numbers with a For/Next loop everything work fine. As soon as I enable Xin the problem is back again.
    At this time it seems I have got only one bullet left "use two pics" one for Xin and one for Xout.
    Al.
    Did you also change the RX handler to receive only 1 byte at a time? Waiting for a whole string takes a LONG time.
    And, have you tried the XIN without the interrupts? Is XIN working at all?
    You can add a Timeout to XIN, in case it's not receiving anything.
    Is the XIN supposed to be running continuously in a loop, or as a response to the 250 command?
    If it was in response to the command, it's more likely that incoming data will not occur again in the middle of the XIN.
    May 2008
    Italy
    Yes I did But it doesn't work very well. A command must be sent twice or three times to be executed, while with the whole string method commands are all decoded and executed correctly at the first time. Very likely my code is not so efficient as the whole string.
    Here the code used: (Where : RxBuffer VAR PIR1.5)
    Getbytes:
    A0=0
    While RxBuffer=1
    Hserin 100,ErrorFlag,[Rdata[A0]]
    A0=A0+1
    Wend
    @ INT_RETURN
    Yes with "SERIN2/SEROUT2" did work, not with "HSERIN/HSEROUT". But as you can understand, I need to jump out from Xin loop when an X10 command is received via Xbee in order to service it with the Xout command.
    Xin is supposed to continuouly scan the main for X10 commands coming in from the different sources capable to issue such a command. The incoming data will be used to update a memory area containing the status of various lamps and appliances (On/Off).
    Al.
    how about get rid of the timeout label and the IF-THEN?
    Dec 2005
    As written, Xin is blocking. You need a timeout and jump_to_label.
    May 2008
    Italy
    Steve, are you refering to the code in my post#11?
    dhoston, Xin is blocking the USART with and without the timeout
    Al.
