HSERIN and XOUT command
Results 1 to 21 of 21
    Are you using the TX pin for XOUT? If so, yes It may give you some weird problem, because XOUT may try to modify the TRIS setting, and/could disable the USART.
    Try
    RCSTA=0 before XOUT
    RCSTA=$90 after Xout
    and see how good, worst it is.
    From what I know, there's no good reason why MODEDEFS should solve the problem. If it wasn't there, you would probably have some compilation error but not much.
    May 2008
    Italy
    Thank you Joe and Steve,
    Pins RB1(Rx) and RB2(Tx) are used to service the serial connection with the Xbee module. Xout uses pin RB6; Xin uses pin RB4 and zerocrossing is on pin RB6. Here the code:
    INCLUDE "Modedefs.bas"
    INCLUDE "DT_INTS-14_2.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    CMCON   = 7
    TrisA = %00000000
    TrisB = %00110010
    PortA = 0
    DEFINE OSC 10
    DEFINE HSER_SPBRG 64  ' 9600 Baud @ 10MHz, 0,16%
    XbDtr       var PortB.0
    XbRts       var PortB.3
    XbSlp       var PortA.3
    Pwr         var PortA.0
    Led         var PortA.1
    Buz         var PortA.2
    X10Rx       var PortB.4
    ZCrox       var PortB.5
    X10Tx       var PortB.6
    TxEnable    var PortB.7
    high Pwr
    high XbSlp
    low TxEnable
    low XbRts
    Low XbDtr
    A0          var Byte
    House       var byte
    Unit        var Byte
    Job         var Byte
    Decode      var byte
    Pass        var byte
    Rdata       var Byte[10]
    HouseKey    var word
    '--------------------------- Rx DT interrupt definition -------------------
            INT_Handler    RX_INT,   _Getbytes,     PBP,  no
    @     INT_ENABLE  RX_INT     ; enable RX_INT interrupts
    gosub Buzzer
    pause 1
    If Rdata[0]=250 then loop
    Getbytes:
    Hserin 100,ErrorFlag,[str Rdata\9]
    High led
    If Rdata[0]=36 then
    House = ((Rdata[4]-48)*10) + (Rdata[5]-49)
    Unit = ((Rdata[6]-48)*10) + (Rdata[7]-49)
    Decode = Rdata[8]-48
    If decode = 1 then Job = 18 : Pass = 1
    If decode = 2 then Job = 26 : Pass = 1
    If decode = 50 then Job = 20: Pass = 1
    If decode = 51 then Job = 28: Pass = 1
    gosub TxCommand
    Pass=0
    Low led
    @ INT_RETURN
    ErrorFlag:
    RCSTA.4 = 0
    RCSTA.4 = 1
    Pass=0
    low led
    @ INT_RETURN
    TxCommand:
    If Pass=0 then return
    High TxEnable
    pause 1
    Xout X10Tx,Zcrox,[House\Unit,House\Job]
    low TxEnable
    Buzzer:
    high buz
    pause 20
    low buz
    Loop:
    xin X10Rx,ZCrox,[Housekey]
    hSerout ["H: ",#Housekey.byte1,13,10]
    hserout ["K: ",#Housekey.byte0,13,10]
    goto loop
    Now the code works with the exception of HSEROUT that I was anable to get it to work in the "Main" loop. I had to make the trick to jump in a secondary loop "LOOP" to have it working, but if I re-enter the "LOOP" the second time then HSEROUT doesn't work anymore. There must be something effecting the USART setting using Xin and Xout command.
    I should mention once again that pic16F628 is working @ 3.3 Volts. No compilation errors without Modedefs.bas file.
    Any tip will be welcome!
    Al.
    Hi Aratti,
    This could be a problem.
    In the Main loop, actually Loop:, there is an XIN statement that runs on every loop. Then if you receive data in the interrupt handler, the TxCommand is called which does an XOUT. The XOUT could potentially be triggered in the middle of the XIN. Possibly leaving XIN waiting for something it will never receive.
    That could keep the HSEROUT's from being executed.
    If you set a "flag" in the interrupt handler when it receives data, then do the XOUT in the main loop when it sees the flag, it won't try to do both XIN and XOUT at the same time.
    Added: You may also need to have the RX interrupt receive bytes 1 at a time instead of a full string, to keep it from interfereing with the XIN to begin with.
    hth,
    May 2008
    Italy
    Default No luck
    Hi Darell, thank you for your answer. I did try your suggestion without any luck.
    In doing these changes I came to the conclusion that Xin command is the problem, infact simply removing Xin from the code and Txing numbers with a For/Next loop everything work fine. As soon as I enable Xin the problem is back again.
    At this time it seems I have got only one bullet left "use two pics" one for Xin and one for Xout.
    Al.
    Did you also change the RX handler to receive only 1 byte at a time? Waiting for a whole string takes a LONG time.
    And, have you tried the XIN without the interrupts? Is XIN working at all?
    You can add a Timeout to XIN, in case it's not receiving anything.
    Is the XIN supposed to be running continuously in a loop, or as a response to the 250 command?
    If it was in response to the command, it's more likely that incoming data will not occur again in the middle of the XIN.
    May 2008
    Italy
    Yes I did But it doesn't work very well. A command must be sent twice or three times to be executed, while with the whole string method commands are all decoded and executed correctly at the first time. Very likely my code is not so efficient as the whole string.
    Here the code used: (Where : RxBuffer VAR PIR1.5)
    Getbytes:
    A0=0
    While RxBuffer=1
    Hserin 100,ErrorFlag,[Rdata[A0]]
    A0=A0+1
    Wend
    @ INT_RETURN
    Yes with "SERIN2/SEROUT2" did work, not with "HSERIN/HSEROUT". But as you can understand, I need to jump out from Xin loop when an X10 command is received via Xbee in order to service it with the Xout command.
    Xin is supposed to continuouly scan the main for X10 commands coming in from the different sources capable to issue such a command. The incoming data will be used to update a memory area containing the status of various lamps and appliances (On/Off).
    Al.
    how about get rid of the timeout label and the IF-THEN?
