I'm back. My current circuit didn't work and was to big. I need your help on designing a whole new circuit. What I need it to do is when 12VDC is put in to the circuit it needs to work a relay that uses the same 12VDC out of its point to produce pulses to honk the horn relay. I need the beeps to be adjustable from 1 to 8-10 beeps. Then I need a external switch that if it is on then the circuit won't put anything out. Then I need to monitor the ignition switch. If it is on then the circuit should not put anything out. That is it for the requirements. I am sooooo thankful that I found this forum and that ya'll are on it. I thankyou for your help soooo much.
