Compiler not creating .hex files for programmer.
Results 1 to 12 of 12
    In a first time, to get something usable, you could use MPLAB to generate the Hex file, and then use your programmer alone.
    Sure, First thing I would do is re-install Microcode ...
    BTW: do You get any Error or Warning messages at compile time ???
    Only way I can see that happening is if MCS is set to use MPASM and there is no (working) mpasm of if the path to mpasm is incorrect. So as Alain said . . . or reinstall mpasm.
    Oh, and not to forget my manners . . . again . . . Welcome to the forum.
    May 2009
    Thanks a lot!
    I'm going to look into the things you suggested and I noticed some progress already.
    I'll return if something bad comes up.
    Thank you so much for the good attitude!
    May 2009
    Still no improvements, no HEX file is being created and the reset button is still not functional.
    EDIT: Problem solved.
    Question
    Hi, Teknikum
    Looks strange ... Which is your PBP release ???
    By the time, I Turned to MCS + ... compile still Ok, download to my programmer Ok too ...
    So :
    1) There's no reason for MCS not to create the Hex file ...
    except you try to use MPASM and you didn't install MPLAB on your computer. ( cf Joe's answer )
    Check: View\ Compile and Program Options\Assembler and verify " use MPASM " is NOT selected.
    OR PM Assembler could have been damaged ( ??? ) in the PBP folder ...
    Re-install your FULL PBP program, then ...
    2) The " reset " button do not belong to MCS ... if there's no Hex file to program, nor hex file in your processor, the " reset " can't show anything visible ...
    Now, I Can't help you further ...
    Last edited by Acetronics2; - 14th May 2009 at 13:18. Reason: Arrrghhhh, ons second later : which was the problem ???
    Default setting up the software
    May 2009
    Thanks for the help, we have worked it all out now.
    By the way, this is a school-account that is made with permission from the teacher since he is worse than we are, we are several students using it so don't get confused if something else comes up.
  1. Creating your own .inc files
    By mjphillips1981 in forum mel PIC BASIC Pro
    Last Post: - 27th May 2009, 12:46
