Compiler not creating .hex files for programmer.
Results 1 to 12 of 12
    May 2009
    Ok, here it is.
    DEFINE LOADER_USED 1
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    ' Define ADCIN parameters
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    adval var byte
    ADCON1 = %00000010
    LOW PORTE.2
    PAUSE 500
    loop: ADCIN 0, adval
    LCDOUT $FE, 1
    LCDOUT "Value:", DEC adval
    PAUSE 500
    Lightbulb ???
    :020000040000FA
    :04000000B201DA2847
    :080008000408A700891009108B
    :10001000091083168910091009100F308805831202
    :100020002708B21830283A30A100FC30A020333025
    :10003000A60044201030A1006830A0204420643085
    :100040009F202230A600442028302F200C302F2063
    :1000500001302F2006302F20B21427083028321408
    :10006000A600321C3E280910033C031C43284320F1
    :100070000530A100DC30A020031408003214FE3C3F
    :100080000319D5280914321C321089140F30880541
    :100090002608F03988048910A60E321844282C301E
    :1000A0009F2003140800B31329080319B317053060
    :1000B000A8002730A300103069200330A300E830E7
    :1000C0006920A30164306920A3010A306920240853
    :1000D0007028A2002508A1002408A000B420200850
    :1000E000A000A8030319B313290803197A282802CA
    :1000F000031808002008031DB313B31B0800303E8B
    :10010000D028A000A00DA00D200D3839C1389F00C7
    :100110000030A1003230A0201F151F198D28A10129
    :100120001E08D528A301A200FF30A207031CA307C5
    :10013000031CD5280330A100DF30A0209428A101A2
    :10014000E83EA000A109FC30031CA928A007031861
    :10015000A628A0076400A10FA6282018AF28A01C7D
    :10016000B3280000B3280800A501A4011030A600A0
    :10017000210DA40DA50D2208A4022308031C230FA2
    :10018000A5020318CA282208A40723080318230F6E
    :10019000A5070310A00DA10DA60BB8282008D5288F
    :1001A000840031088A00300882008313031383120D
    :1001B00064000800831602309F0083120911831621
    :1001C000091183120130A300F4308A01932000301A
    :1001D0008A018120B800FE308A01052001308A01A1
    :1001E000052056308A01052061308A0105206C30D7
    :1001F0008A01052075308A01052065308A010520B5
    :100200003A308A010520A9013808A400A50104306C
    :10021000B000B1018A0153200130A300F4308A01FB
    :08022000932063008A011129FB
    :00000001FF
    so ... it compiles as-is !!! just striking the " compile " button ...
    Could you explain what do you want to do and What you do ???
    Now, I do not tell you some small things are missing ... but there is no compiling problem ...
    May 2009
    It doesn't matter what code I want to compile, I know that my code is 100% correct because we learn directly from the book and we have written about 14 programs that worked before.
    But now when we wanted to compile with the MicroCode Studio Plus, it stopped to create .hex-files. Without the .hex files we can't use the Melabs programmer and if we use Microcode Studio Plus as a programmer, the processor won't be able to reset with the resetbutton, that's also one problem.
    We checked some other lab-chipsets, we checked voltage and other stuff, but it's all new stuff so..
    For example, one program is called "4.1"
    These files are saved when I compile it:
    4.1.pbp
    4.1.asm
    4.1.mac
    4.1.sym
    4.1.lst
    4.1.map
    but no .hex!
    I'm sorry if I can't explain very good, I'm new at this.
    In a first time, to get something usable, you could use MPLAB to generate the Hex file, and then use your programmer alone.
    Sure, First thing I would do is re-install Microcode ...
    BTW: do You get any Error or Warning messages at compile time ???
    Only way I can see that happening is if MCS is set to use MPASM and there is no (working) mpasm of if the path to mpasm is incorrect. So as Alain said . . . or reinstall mpasm.
    Oh, and not to forget my manners . . . again . . . Welcome to the forum.
    May 2009
    Thanks a lot!
    I'm going to look into the things you suggested and I noticed some progress already.
    I'll return if something bad comes up.
    Thank you so much for the good attitude!
    May 2009
    Still no improvements, no HEX file is being created and the reset button is still not functional.
    EDIT: Problem solved.
  1. Creating your own .inc files
    By mjphillips1981 in forum mel PIC BASIC Pro
    Last Post: - 27th May 2009, 13:46
