When I compile the program I've written, the compiler won't create any hex-file which I need to program the processor. The model name is 16F877A version 3.0.0.5 and the programmer is from meLabs version 4.24.
Any ideas?
Any ideas?
The best Idea here: Post your code, please ...
Ok, here it is.
DEFINE LOADER_USED 1
DEFINE LCD_DREG PORTD
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTE
DEFINE LCD_RSBIT 0
DEFINE LCD_EREG PORTE
DEFINE LCD_EBIT 1
' Define ADCIN parameters
DEFINE ADC_BITS 8
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
adval var byte
ADCON1 = %00000010
LOW PORTE.2
PAUSE 500
loop: ADCIN 0, adval
LCDOUT $FE, 1
LCDOUT "Value:", DEC adval
PAUSE 500
so ... it compiles as-is !!! just striking the " compile " button ...Code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
Could you explain what do you want to do and What you do ???
Now, I do not tell you some small things are missing ... but there is no compiling problem ...
It doesn't matter what code I want to compile, I know that my code is 100% correct because we learn directly from the book and we have written about 14 programs that worked before.
But now when we wanted to compile with the MicroCode Studio Plus, it stopped to create .hex-files. Without the .hex files we can't use the Melabs programmer and if we use Microcode Studio Plus as a programmer, the processor won't be able to reset with the resetbutton, that's also one problem.
We checked some other lab-chipsets, we checked voltage and other stuff, but it's all new stuff so..
For example, one program is called "4.1"
These files are saved when I compile it:
4.1.pbp
4.1.asm
4.1.mac
4.1.sym
4.1.lst
4.1.map
but no .hex!
I'm sorry if I can't explain very good, I'm new at this.
In a first time, to get something usable, you could use MPLAB to generate the Hex file, and then use your programmer alone.
Sure, First thing I would do is re-install Microcode ...
BTW: do You get any Error or Warning messages at compile time ???
