pic16F628
Results 1 to 6 of 6
Thread: pic16F628
    Apr 2009
    Default pic16F628
    hi every one
    can any one help me with this... plzzzzzzzz
    i use Pic16F628 for a senior project and i want to know how to write a code for store 2 dimensional array and how to compare two regular array ??
    i use pro picbasic .
    thanks in advance
    Hello Ilham,
    You might have to tell the rest of us a little more about what you are trying to do. As far as multidimensional arrays, I did a search and found this thread:
    http://www.picbasic.co.uk/forum/show...2093#post32093
    http://www.scalerobotics.com
    Apr 2009
    Default pic16f628
    hello scalerobotics
    I'm a Beginner in this field ,
    we are trying to make an electronic wallet by using this Pic
    and we want to programmed it to be open with a password
    so we want to set the password in array to make a comparison with the enter password by user in order to check if it correct or not
    i hope i make it much clear
    Ok, that makes sense. I think you could do it simply by making two arrays, and comparing their contents. You might want more bytes if you need it more secure. You could do it this way:
    passkeyed var byte[6]   'entered (keyed) password
    passcode var byte[6]    'stored pass word
    for n = 0 to 5
       if passkeyed[n] != passcode[n] then failure   'if passkeyed[n] does not equal passcode[n]
    next n
    'if passkeyed passes, your program will get here
    failure:   'failure subroutine here
       'get here only if you failed password entry
    May 2008
    Italy
    Default Entry password
    Go to the following thread : http://www.picbasic.co.uk/forum/showthread.php?t=10637
    You will find the code for different examples. In post#9 you will find my working snippet for an entry password.
    Al.
    Apr 2009
    Default Pic16F628
    thanxxxxxxx so much
  1. Watchdog Timers
    Last Post: - 27th August 2014, 18:03
  2. Help please about pic16f628
    By eee1984 in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 13:56
  3. Need help intergating a PIC16F628 with a DS1307
    By PNightmare in forum mel PIC BASIC Pro
    Last Post: - 30th October 2007, 19:45
  4. help pic16f628 and 115200
    By physics2000 in forum Serial
    Last Post: - 26th October 2005, 17:06
  5. Serout PIC16F628 to PC R18iXL Board
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 19th June 2005, 00:29
