hi every one
can any one help me with this... plzzzzzzzz
i use Pic16F628 for a senior project and i want to know how to write a code for store 2 dimensional array and how to compare two regular array ??
i use pro picbasic .
thanks in advance![]()
hi every one
Hello Ilham,
You might have to tell the rest of us a little more about what you are trying to do. As far as multidimensional arrays, I did a search and found this thread:
http://www.picbasic.co.uk/forum/show...2093#post32093
http://www.scalerobotics.com
hello scalerobotics
I'm a Beginner in this field ,
we are trying to make an electronic wallet by using this Pic
and we want to programmed it to be open with a password
so we want to set the password in array to make a comparison with the enter password by user in order to check if it correct or not
i hope i make it much clear![]()
Ok, that makes sense. I think you could do it simply by making two arrays, and comparing their contents. You might want more bytes if you need it more secure. You could do it this way:
Code:passkeyed var byte[6] 'entered (keyed) password passcode var byte[6] 'stored pass word for n = 0 to 5 if passkeyed[n] != passcode[n] then failure 'if passkeyed[n] does not equal passcode[n] next n 'if passkeyed passes, your program will get here end failure: 'failure subroutine here 'get here only if you failed password entry return
Go to the following thread : http://www.picbasic.co.uk/forum/showthread.php?t=10637
You will find the code for different examples. In post#9 you will find my working snippet for an entry password.
Al.
