need help in lookup
Results 1 to 28 of 28
    Apr 2009
    It works here, I tried it first on 16f690, and this version on 16f628A, 16f648A and it works on both, I uses a simple blinky to drive the count as it's output is clean unlike a switch.
    hi joe, im using dsr display which has ic 74hc164 and 4 wires for each digits now i know there no ports output to count digits throu the lcd ,and ur code it works just 1 digit when i plug 1 dgit wire to the GND, i wanted to enable each port to change digits for shiftout and i use pic16f84, sorry for bothering you that much joe and thank you so much for teaching me ,
    define _config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF &_CP_OFF & _BODEN_OFF & _LVP_OFF
    SDO Var PortB.4
    SCLK Var PortB.5
    DLE Var PortB.7
    EECON1 = 7
    B0 Var WORD
    B1 Var byte
    D1 Var byte
    D10 Var byte
    D100 Var byte
    D1000 Var byte
    ONES Var Byte
    TENS Var Byte
    HUNS Var Byte
    THOUS Var Byte
    'WPUA = %00110001
    'ANSEL = 0 ' FOR USE IN 16F690
    'ANSELH = 0
    'CCP1CON = 0
    'CM1CON0 = 0
    'CM2CON0 = 0
    'CMCON = 7 ' Disable comparators 16F648A
    OPTION_REG = 0 '16f628a
    'OPTION_REG = %00111000 ' set for 16f690
    data @0,252,96,218,242,102,182,190,224,254,246
    Pause 10
    PORTB = 0
    PORTA = 0
    TRISB = %00000000 ' lower 4 pins outputs
    TRISA = %00001 ' RA2 = TMR0 clock input
    B0 = B0+B1 'STORE THE RESULTS BETWEEN COUNTER LOOPS
    If B0 >= 9999 then B0 = 0
    D1 = b0 DIG 0 ' Load Thousands Digit
    Read D1, ONES ' Convert and Load Thousands Variable
    d10 = B0 DIG 1 ' Load Hundreds Digit
    READ D10,TENS ' Convert and Load Hundreds Variable
    D100 = B0 DIG 2 ' Load Tens Digit
    READ D100,HUNS ' Convert and Load Tens Variable
    D1000 = B0 3 ' Load Ones Digit
    READ D1000,THOUS ' Convert and Load Ones Variable
    Shiftout SDO,SCLK,4,[ONES\8,TENS\8,HUNS\8,THOUS\8] 'when it shiftout it needs to eneble each digits bcz i have 4 wires i 'donno where i add them in this code so when it shiftout the 0 dig it enebles digit 1 on lcd then 2 so on i use digital satellite receiver 7 segments 4 digit it has 74hc164 for serial input data and clock then paralil output to 7 segments and each 1 wire ,from each digit i wanted to plug them in the pic so i need to eddit the code im still trying lol'
    PAUSE 10
    HIGH PORTB.7
    pulsout DLE, 125
    pause 12
    Goto MAIN
    Apr 2009
    still waiting help, in this 7 seg with 74 hc164 ,i drawed a sample schema , thanks
    Quote Originally Posted by malwww View Post
    SDO Var PortB.4
    SCLK Var PortB.5
    DLE Var PortB.7
    EECON1 = 7
    B0 Var WORD
    B1 Var byte
    D1 Var byte
    D10 Var byte
    D100 Var byte
    D1000 Var byte
    ONES Var Byte
    TENS Var Byte
    HUNS Var Byte
    THOUS Var Byte
    'WPUA = %00110001
    'ANSELH = 0
    'CCP1CON = 0
    'CM1CON0 = 0
    'CM2CON0 = 0
    Pause 10
    PORTB = 0
    PORTA = 0
    PAUSE 10
    HIGH PORTB.7
    pulsout DLE, 125
    pause 12
    Goto MAIN
    OK, it took some hair pulling as I am not really good with arrays.
    here is a sample as to how to do this. What you want to do is load the variable with the value to display, and display that digit, then do the next and the next. Using an array to hold the value:
    Goldfish var byte ' cause it's late and I am tired
    Digit var byte[4] ' 4 variables all named digit, an array
    index var byte    ' a counting variable
    displays var word ' from the program
    digit_output var byte 'from the program
    ' this code changed from program
    loop:
    DIGIT_OUTPUT = DISPLAYS dig 0 ' Load Thousands Digit
    READ DIGIT_OUTPUT, DIGIT.0    ' Convert and Load Thousands Variable
    DIGIT_OUTPUT = DISPLAYS DIG 1 ' Load Hundreds  Digit
    READ DIGIT_OUTPUT, DIGIT.1    ' Convert and Load Hundreds Variable
    DIGIT_OUTPUT = DISPLAYS DIG 2 ' Load Tens of Units Digit
    READ DIGIT_OUTPUT, DIGIT.2    ' Convert and Load Tens  Variable
    DIGIT_OUTPUT = DISPLAYS dig 3 ' Load Ones of Units Digit
    READ DIGIT_OUTPUT, DIGIT.3    ' Convert and Load Units Variable
    ' notice the digits were changed to reflect the array variable name
    'here is where we do the magic
    for index = 0 to 3  '  loop 4 times
    Goldfish = digit[index]  ' load goldfish with the digit values
    shiftout SDO,SCLK,4,[Goldfish\8]  ' send the values to display
    portC.0[index] = 1 ' here we energise each display digit in sequence
    PAUSEUS 900 ' this number alters the brightness verses display flash rate
    PORTC=0 ' this blanks the numbers between loading data so it does not read 8888
    next index ' select the next digit
     GOTO LOOP
    you notice the word index in red, this syncronizes the digit selection on portc with the data being shifted out.
    Apr 2009
    loop:
     GOTO LOOP
    thnk u joe i will try it out and try to pull some hair with it,lol
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 11:38
  3. ADCIN and LOOKUP ...
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 22:02
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  5. Confused On Dig & Lookup
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 22:49
