Hello malwww,
If you have been following other threads, you have seen a similar one to yours. If you are using byte variables only then use lookup instead of lookup2 as the code is 1/3 as big and you can use a table of up to 255 choices. Lookup2 gives only 85 choices, which can be byte or word variables.
