PIC16F877 to PC via max232 HELP!!
Results 1 to 16 of 16
    Terry Blackwell's Avatar
    Terry Blackwell Guest
    Default max232
    yes the invert? PIC to PIC a 1 is a 1 or a 0 is a 0 but the max chip turns input 1 from your pic in to an output o so you have to invert a 1 to 0 and a 0 to 1. Hock it up to your PC RS232 port you should get something anyway. I have used Pic16f628 and it works fine I only us MPLAB MPASM when I'm programming PIC you can do a lot and have more control of your PIC.
    Hi Terry,
    Yeah, I'd love to do Assembler as well. I was 2nd in my class when I graduated in '83. And most importantly, I actually loved writing in Assembler, it came naturally.
    But a few, ahem, years have gone by since then and I haven't touched Assembler since. I figure I'll get back into it slowly, once I get this project done. Assembler is the best way to go, total control. But I'm taking WAY longer than originally anticipated when I started this. I didn't even expect to program MCUs when I decided to make my little controller; just buttons and LEDs. Yeah, right...
    Ok, so I knew nothing of electronics when I started 18 months ago, but hey, I'm managing. LOL I'm a little slow in some areas (like 99%), but once I get something going, I keep building on it. I'll stick to BASIC Pro for now, since BASIC was the 1st language I learned, and that was, ahem, the day it came out.
    Fortran, Pascal, RPG, COBOL, name the oldies, I've done them. It's the new generation languages from C and up that I lack. I never thought I'd say that I wished I knew Assembler on the tip of my fingers again though...
    sundaecone's Avatar
    sundaecone Guest
    Default follow-up question T_T
    wow, this thread has been extremely useful, but i have a follow-up question..
    i noticed that the crystal that loredana used was a 20MHz, i just wanna know what the maximum baud rate is for this crystal and also for the 4MHz crystal?
    thanks so much!!! ^_^
    Based on internal USART: all will depend wich BRG setting you're using and % error you want to deal with..
    Let's say PIC16F877 @20MHZ, all the answers are in the datasheet section 10 Table 10-4. Like every PIC that have USART.
  1. Direct PIC to PC without MAX232
    By acjacques in forum Serial
    Last Post: - 23rd October 2014, 21:32
  2. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  3. PIC16F877 sends/receives data to/from a PC
    By ovidiu in forum Serial
    Last Post: - 2nd December 2006, 14:09
  4. USB interface from PIC16F877 to PC
    By headshouter in forum USB
    Last Post: - 26th February 2006, 04:58
  5. connecting pic16F877A to pc via max232
    By zikha in forum mel PIC BASIC Pro
    Last Post: - 12th January 2006, 15:31
