HSERIN [WAIT("**play#")STR data\6]
wait for **play# then then next 6 characters will be present in data, well I wish, I get an error with syntax
ERROR Line 59: Expected ']'.
you're really close!!! just a ',' is missing + array variable definition
' Variable Definition
SerData var byte [6]
Start:
' Program begining/Main Loop
HSERIN [WAIT("**play#"),STR serdata\6]
hserout [str serdata\6]
goto start
the above will echo you the next 6 character next to your **play#
Also I read in the manual STR ArrayVar\n{\c}
Receive string of n characters optionally ended in character c
Does this mean I dont have to specify the value of n
HSERIN [WAIT("**play#")STR data\n\"!"]
wait for **play# and copy the next characters upto the ! to data.
nop ... wait for **play# and copy the next 'n' character or previous ones if the last one is '!'.
must be write HSERIN [WAIT("**play#"), STR lala\n\"!"]
Hope I am not imterupting you steve with all these questions.
Since i answer to this... no. Don't be afraid. We're all here to learn/help as we can.
