ADval*/Quanta Question
Results 1 to 8 of 8
    Take VDD divided by the MAX A/D reading, and multiply times 256.
    5 / 1023 * 256 = 1.251
    Scale that up to however many decimal places you want.
    For 3 decimal places, multiply by 1000.
    = 1251
    So your current number is correct for 10-bit A/D with 3 decimals. (0-4999)
    If you only want 2 decimals as indicated in your post, use 125 instead. (0-499)
    Or you can calculate to 3 decimals, then add 5 and divide by 10 and you'll get a rounded number. (0-500)
    4999 + 5 = 5004, /10 = 500
    Thanks Darrel for your formulae. Substituting 1023 for the 5 I get
    1023/1023*256 *10=2560(Quanta). I was using 2600,now from Pic this gives true 10bit number(1023) at full scale that is sent to pc to be scaled,damped,averaged etc.
    Tom
    What?
    That's completely self defeating. The A/D converter already put's out 0-1023.
    With the */ operator, all your formula does is multiply it times 2560 and divide by 256, which is the same as just saying ADval * 10.
    So you would actually be sending 10230.
    I don't think that's what you wanted.
    If you want to send 0-1023 to the PC, just send the ADval.
    Thanks Darrel
    Now I understand, Adval by itself returns 102? and when Adval=Adval*10 it returns 1023 which is what I am using.
    Thanks again.
    Tom
    Don't thank me yet.
    Cuz it looks like there's still some misunderstandings.
    With the Analog to Digital converters, you have two choices (8-bit or 10-bit).
    8-bit returns values from 0-255.
    10-bit values are from 0-1023.
    Those numbers come straight from the converter without any additional math needed.
    Without seeing your code, I can only guess at what's happening.
    My guess is that before sending to the PC, you are breaking the numbers down with the DIG operator.
    DIG starts at 0, with 0 indicating the rightmost digit.
    If ADval was holding the value 1023, (ADval DIG 0) would be 3.
    DIG  3210
         1023
    If you're thinking the rightmost digit is 1, and you used DIG 1 thru 4, it would return 0102.
    Multiplying *10 first would make DIG 1 thru 4 return 1023, although the actual value is 10230.
    Are you using DIG?
    Yes you are right Darrel, I am using DIG 1-4 as you thought. I have now simplified program, since adval does = 1023 directly and using DIG 0-3 to send to PC. All 8 temperature readings now work well.
    Thanks again
    Tom
    Sep 2005
    Campbell, CA
    Maybe this isn't the right thread, but when A/Ds are mentioned, everyone thinks in terms of 8 or 10 bit resolution. Some chips (8723 for example) return a 12 bit value. That has screwed me up more than once.
    Charles Linquist
  1. ADCIN question
    By Greg McFadden in forum General
    Last Post: - 16th September 2008, 03:53
  2. Remote PIC input question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st September 2007, 16:44
  3. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
  5. Timer / CCP Question
    Last Post: - 2nd November 2005, 09:22
