A/D conversion with PIC18F67J50
Results 1 to 10 of 10
Threaded View
  1. #5
    You conversion clock seems a bit high @48MHz operation, and your first example in C used ANCON0, not yours.... yet...
    While it's not a problem for now, one day you may need to disable some analog feature on this PIC... however, seems ANCON0 and ANCON1 are not included in PBP 2.50c, so I guess the following would be handy one day or another.
            '       Configure ADC
            ANCON0  VAR BYTE EXT    ' not included in PBP2.50c
            ANCON1  VAR BYTE EXT    ' not included in PBP2.50c
            ANCON0 = %10011110
                   '  -xx------ Not Implemented
                   '  1--1111-- AN7, & AN<4:1> = Digital
                   '  -------0- AN0 = Analog
            ANCON1 = %11111111
                   '  11111111- AN<15:10> = Digital
            ADCON0 = %00000001
                   '  0-------- VCFG1, Vref- 0 = AVss (1=AN2)
                   '  -0------- VCFG2, Vref+ 0 = AVdd (1=AN3)
                   '  --0000--- CHS<3:0>, Channel select -- 0
                   '  ------0-- Go/Done, don't care for now
                   '  -------1- ADON, Enable ADC
            ADCON1 = %10000111
                   '  1-------- ADFM, Right justified result
                   '  -0------- ADCAL, Normal A/D converter operation
                   '  --000---- ACQT<2:0>, A/D Aquisition time = 0 Tad
                   '  -----111- ADCS<2:0>, A/D conversion clock = FRC
            '       Hardware Aliases
            GoDone      var ADCON0.1 ' StartConversion = 1, Conversion done = 0
            '       Software Variables
    @ADVal = ADRESL
            ADVal       VAR WORD EXT
    Start:
            pauseus 10  ' Acquisition time
            GoDone = 1
            While GoDone : Wend
            LCDOUT $FE, 1, "Value: ", DEC ADVal
            PAUSE 250
            GOTO START
    EDIT: for some odd reason, ANCON0 & ANCON1 are commented in PIC18EXT.BAS, i'd sent an e-mail to Melabs, obviously they must have a reason for that.
  1. Fast / low resolution A/D conversion
    By AndrewC in forum General
    Last Post: - 7th April 2009, 12:18
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 16:26
  3. A/D conversion problem on 18F4431
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 23:03
  4. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 18:57
  5. Strange A/D conversion...
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 5th June 2005, 01:35
