A/D conversion with PIC18F67J50
Results 1 to 10 of 10
    I believe it's the ADCON0 = %00000000 'turn off adc
    You probably get a reading the first loop through.
    But for all loops after that, the A/D module is turned off.
    Thanks Darrel,
    I commented out my ADCON0 = %00000000 and put the loop back in, and confirmed my loop is looping. My result seems to be stuck at 24543, 40910 or 8142 each time I reset. Basically giving me random numbers as best I can tell. But despite the loop looping, the numbers do not change, until I remove power from the unit, then apply power again.
    DEFINE OSC 48
    include "modedefs.bas"
    include "LCD_3310.pbp"
    TRISD = 0
    PORTD.0 = 1   'turn on g sensor
    PORTD.1 = 0   'select scale for g sensor
    PORTD.2 = 0   'select scale for g sensor
    TRISA = %00000111   'set porta.0, 1, and 2 as inputs
    TRISB = 0
    CM1CON = 7
    CM2CON = 7
    TRISC = 0
    TRISE = 0
    ADCON0 = %00000001      'turn on adc
    ADCON1 = %00000010      'fosc/32 ??
    'am I translating c language ADCON1=0x10 above correctly?
    resx var word
    x var word
    y var word
    z var word
    adval var word
    x=0
    y=0
    z=0
    adval = 0
    PORTD.0 = 1   'turn on g sensor (again)
    @ bsf WDTCON,ADSHR   ;set shared address SFR with WTCON<4> - is this right?
    ADCON0 = %11111110  ' channel with a 0 is analog input, all others digital
    @ bcf WDTCON,ADSHR
    ADCON1 = %10111110  'right justified, AD=20AD, A/D clock=fosc/64
    ADCON0.0 = 1        'turn on adc
    ADCON0.2 = 0        'channel select bit CHS0(should already be a 0)
    ADCON0.3 = 0        'Channel select bit CHS1(should already be a 0)
    start:
        Pause 500       ' Wait .5 second
    loop: 		ADCON0.1 = 1					'Start Conversion
    adval = 0                                   'clear result word
    notdone:	pause 5
    	if ADCON0.1 = 1 Then notdone	'wait for low on bit-2 of ADCON0, conversion finished
    	adval.highbyte = ADRESH			'move HIGH byte of result to adval
    	adval.lowbyte = ADRESL			'move LOW byte of result to adval
            'ADCON0 = %00000000              'turn off adc
            'Lcdout $fe, 1   				'Clear screen
            'Lcdout "Value: ", DEC adval	'Display the decimal value
                x = x +1                        'test to see if loop is working
    @ PrintStr 0,0, "Z= "                       ;display on Nokia 3310
    @ PrintVar 24,0, _adval                     ;display result on 3310
    @ PrintVar 0,1, _x                          ;show if loop is looping
            Pause 100       				'Wait .1 second
           	Goto loop       				'Do it forever
    http://www.scalerobotics.com
    Whoops,
    I noticed that it was going to my include file, then popping up at start: which missed all my settings to the ADCON0 etc.
    Sometimes I have to say it out loud (to everyone) to figure it out, with the help of some experts. I won't tell anyone how many days I was trying..........
    Walter
    You conversion clock seems a bit high @48MHz operation, and your first example in C used ANCON0, not yours.... yet...
    While it's not a problem for now, one day you may need to disable some analog feature on this PIC... however, seems ANCON0 and ANCON1 are not included in PBP 2.50c, so I guess the following would be handy one day or another.
            '       Configure ADC
            ANCON0  VAR BYTE EXT    ' not included in PBP2.50c
            ANCON1  VAR BYTE EXT    ' not included in PBP2.50c
            ANCON0 = %10011110
                   '  -xx------ Not Implemented
                   '  1--1111-- AN7, & AN<4:1> = Digital
                   '  -------0- AN0 = Analog
            ANCON1 = %11111111
                   '  11111111- AN<15:10> = Digital
            ADCON0 = %00000001
                   '  0-------- VCFG1, Vref- 0 = AVss (1=AN2)
                   '  -0------- VCFG2, Vref+ 0 = AVdd (1=AN3)
                   '  --0000--- CHS<3:0>, Channel select -- 0
                   '  ------0-- Go/Done, don't care for now
                   '  -------1- ADON, Enable ADC
            ADCON1 = %10000111
                   '  1-------- ADFM, Right justified result
                   '  -0------- ADCAL, Normal A/D converter operation
                   '  --000---- ACQT<2:0>, A/D Aquisition time = 0 Tad
                   '  -----111- ADCS<2:0>, A/D conversion clock = FRC
            '       Hardware Aliases
            GoDone      var ADCON0.1 ' StartConversion = 1, Conversion done = 0
            '       Software Variables
    @ADVal = ADRESL
            ADVal       VAR WORD EXT
    Start:
            pauseus 10  ' Acquisition time
            GoDone = 1
            While GoDone : Wend
            LCDOUT $FE, 1, "Value: ", DEC ADVal
            PAUSE 250
            GOTO START
    EDIT: for some odd reason, ANCON0 & ANCON1 are commented in PIC18EXT.BAS, i'd sent an e-mail to Melabs, obviously they must have a reason for that.
    Thanks mister_e ! I have flipped to page 299 to 302 so many times but never noticed the "D" to "N" change. Doh!
    Do you think it is edited out because it is a shared address, only distinguished by the address share bit ADSHR in the WDTCON register?
    Currently I have to:
    @ bsf WDTCON,ADSHR 'flag address share bit
    ADCON0 = %11111000 ' channels with a 0 is analog input, all others digital
    @ bcf WDTCON,ADSHR
    (or should I say I think? I have to....)
    to set the aNcon0 register
    (Despite all my mistakes, I am now getting valid conversion results, as of post 4)
    Holly crap, yeah, that make sense indeed. Yet another stupidity from Microchip
    So my example will need some changes...
            '       Configure ADC
            WDTCON.4 = 1    ' Switch to Alternate SFR
            ANCON0 = %10011110
            ANCON1 = %11111111
            WDTCON.4 = 0    ' Back to Default SFR
    or
            '       Configure ADC
            ADCON1 = %10011110  ' alternate ANCON0
            ADCON0 = %11111111  ' alternate ANCON1
    By far, i prefer the first, easier to read
    However, yours work.. keep it like that. If it's not broken, don't fix it!
    Side note... there's no real need to redefine ANCON1, ANCON0 as i did if you use ANCON1_ALT, ANCON0_ALT within your code. Those two are defined in PIC18EXT.BAS.
    Having _ALT written at the right of the register name, may remember you to set/clear WDTCON.4 bit? Maybe
    Sweet! I did not see that either. May be time for glasses. And a lot cleaner than the way I was doing it, and I like the way you wrote the registry bits in the code. That would have kept me from having to divert my attention to and from tfm a lot!
    Thanks for all the help.
    Walter
  1. Fast / low resolution A/D conversion
    By AndrewC in forum General
    Last Post: - 7th April 2009, 13:18
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. A/D conversion problem on 18F4431
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 00:03
  4. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 19:57
  5. Strange A/D conversion...
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 5th June 2005, 02:35
