Usart compile errors 18F4520
Results 1 to 9 of 9
    Pedro Pinto's Avatar
    Pedro Pinto Guest
    Hello again
    With this initialisation i can receive well on the terminal program if i change on that the baudrate to 9600. What can be wrong, it must be 2400, or not?
    DEFINE OSC 16
    ' Initialize USART
    TRISC = %10111111 ' Set TX (PortC.6) to out, rest in
    SPBRG = 25 ' Set baud rate to 2400
    RCSTA = %10010000 ' Enable serial port and continuous receive
    TXSTA = %00100000 ' Enable transmit and asynchronous mode
    hserout ["SCCP",13,10]
    Pedro
    SPBRG = 25 is 2400 baud @4MHZ, not 16MHz.
    If you need 2400 baud @16Mhz you should try those settings
    DEFINE HSER_SPBRG 103 ' 2400 Baud @ 16MHz, 0.17%
    @9600 bauds
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 16MHz, 0.16%
    etc etc etc.
    Try my PICMultiCalc for that.
    Download it from there
    http://www.picbasic.co.uk/forum/atta...7&d=1225550328
    Feb 2009
    Southern California
    Default MR Es Pic Multi-calc
    using Mr E's Multi-calc's recommended settings
    9600 baud
    RCSTA = $90   ' Enable serial port & continuous receive
    TXSTA = $24   ' Enable transmit, BRGH = 1
    SPBRG = 160   ' 9600 Baud @ -0.08%
    SPBRGH = 1
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    2400 baud
    SPBRG = 130   ' 2400 Baud @ 0.0%
    SPBRGH = 6
    The code you posted should have been sending data out at 9600 baud with SPBRG set to 25. Set SPBRG to 103 for 2400 baud. The error rate would be a little higher than the above code snippet (not that it would probably matter in the real world).
    TXSTA = $20 ' Enable transmit, BRGH = 0
    SPBRG = 103 ' 2400 Baud @ 0.17%
    Thanks to Mr E
    David
    Feb 2009
    Southern California
    Wink
    I knew I left that post reply open too long...
    Feb 2009
    Southern California
    Default version 1.3.1
    I didn't realize I was using an old version. I was still on 1.1.0
    Thanks for the update
    David
  1. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 16:43
  2. USB PBPL Compile errors
    By Rob in forum USB
    Last Post: - 7th April 2008, 08:18
  3. USB Mpasm Compile errors
    By JBrannan in forum mel PIC BASIC Pro
    Last Post: - 21st December 2007, 18:13
  4. Replies: 2
    Last Post: - 10th July 2006, 01:05
  5. Compile errors within macro....
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 5th September 2005, 19:08
