Usart compile errors 18F4520
Results 1 to 9 of 9
    Pedro Pinto's Avatar
    Pedro Pinto Guest
    Default Usart compile errors 18F4520
    Hello All
    I try to comunicate via Usart on PORTC.6 and PORTC.7 with Pic 18F4520
    and initiate with this:
    ' Initialize USART
    TRISC = %10111111 ' Set TX (PortC.6) to out, rest in
    SPBRG = 25 ' Set baud rate to 2400
    RCSTA = %10010000 ' Enable serial port and continuous receive
    TXSTA = %00100000 ' Enable transmit and asynchronous mode
    or with this:
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 2400
    DEFINE HSER_SPBRG 25
    DEFINE HSER_CLROERR 1
    but, everytime i want compile the programm it show error messages like:
    Symbol not previously defined (RC2IF)
    Symbol not previously defined (PIR3)
    Symbol not previously defined (RCREG2)
    Symbol not previously defined (TX2IF)
    Symbol not previously defined (SPBRG2)
    Symbol not previously defined (TXREG2)
    Symbol not previously defined (TXSTA2)
    Symbol not previously defined (RCSTA2)
    I use PBP Pro 2.50 and Pic 18F4520
    with instruction like this:
    HSERIN2 800,final,[wait ("P"),dec2 function,dec3 pcb,dec3 dumy]
    Anyone idea what i make wrong?
    Thanks for help
    Pedro
    Try HSERIN instead of HSERIN2.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Pedro Pinto Guest
    Hello Bruce
    Thank You for help
    I have change all Hserin2 and Hserout2 instructions to Hserin and Hserout and the compiler donīt show more error messages
    Do you know why it don't accept the Hersxx2 option?
    Pedro
    Hi Pedro,
    How many hardware USARTs does your 18F4520 have?
    What does your PBP manual state HSERIN2 is for?
    -Bruce
    tech at rentron.com
    Pedro Pinto Guest
    Hello again
    With this initialisation i can receive well on the terminal program if i change on that the baudrate to 9600. What can be wrong, it must be 2400, or not?
    DEFINE OSC 16
    ' Initialize USART
    hserout ["SCCP",13,10]
    Pedro
    SPBRG = 25 is 2400 baud @4MHZ, not 16MHz.
    If you need 2400 baud @16Mhz you should try those settings
    DEFINE HSER_SPBRG 103 ' 2400 Baud @ 16MHz, 0.17%
    @9600 bauds
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 16MHz, 0.16%
    etc etc etc.
    Try my PICMultiCalc for that.
    Download it from there
    http://www.picbasic.co.uk/forum/atta...7&d=1225550328
    Feb 2009
    Southern California
    Default MR Es Pic Multi-calc
    using Mr E's Multi-calc's recommended settings
    9600 baud
    RCSTA = $90   ' Enable serial port & continuous receive
    TXSTA = $24   ' Enable transmit, BRGH = 1
    SPBRG = 160   ' 9600 Baud @ -0.08%
    SPBRGH = 1
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    2400 baud
    SPBRG = 130   ' 2400 Baud @ 0.0%
    SPBRGH = 6
    The code you posted should have been sending data out at 9600 baud with SPBRG set to 25. Set SPBRG to 103 for 2400 baud. The error rate would be a little higher than the above code snippet (not that it would probably matter in the real world).
    TXSTA = $20 ' Enable transmit, BRGH = 0
    SPBRG = 103 ' 2400 Baud @ 0.17%
    Thanks to Mr E
    David
  1. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 16:43
  2. USB PBPL Compile errors
    By Rob in forum USB
    Last Post: - 7th April 2008, 08:18
  3. USB Mpasm Compile errors
    By JBrannan in forum mel PIC BASIC Pro
    Last Post: - 21st December 2007, 18:13
  4. Replies: 2
    Last Post: - 10th July 2006, 01:05
  5. Compile errors within macro....
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 5th September 2005, 19:08
