Pic 18f4620
Results 1 to 4 of 4
Thread: Pic 18f4620
    May 2009
    Default Pic 18f4620
    Hi, I am beginning to program pic with pickit 2; I use micro code studio as compiler, (pbp). I have a problem with pic 18f4620.
    I make this simple program, lampled, but the flashing of the led does not correspond with the program( 1 second on, 1 second off), synchronism lacks.
    This is the program:
    '* Name : UNTITLED.BAS *
    '* Notice : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 27/04/2009 *
    '* Version : 1.0 *
    '* Notes : *
    DEFINE OSC
    TRISB = %00000000
    PORTB = 0
    START:
    PORTB.1 = 1
    PAUSE 1000
    PORTB.1 = 0
    PAUSE 1000
    GOTO START
    The problem is the configuration fuses?
    Tank's Davide.
    Yes and No, you haven't told us which osc speed you're using
    Problem lie more on PORTB.1 and it's multiplexed Analog To digital converter. You want to disable it before using it as digital i/o
    Here's some link for you, keep them handy somewhere.
    PortA Doesn't Work
    All Digital
    http://www.picbasic.co.uk/forum/showthread.php?t=11100
    Presetting Configuration Fuses (PIC Defines) into your Program
    May 2009
    '* Version : 1.0 *
    '* Notes : *
    DEFINE OSC 20
    TRISB = %00000000
    PORTB = 0
    START:
    PORTB.1 = 1
    PAUSE 1000
    PORTB.1 = 0
    PAUSE 1000
    GOTO START
    The frequency is 20 MHz.
    Default Configs Yes
    Hello Davide,
    You have no config settings in your code which indicates to me you are using the default config listed in the pbp\18f4620.inc file, which was designed for 4mhz operation, so you have to either change those configs, comment them out and put the correct ones into your code, or change your resonator and define to 4mhz. Look at the links provided by mister_e.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  4. Coding Style - PIC 18F4620 config fuses
    Last Post: - 8th January 2008, 20:05
