Hello jellis00,
Have you verified the presence and level of the pulses you are counting?
What happens if i = i + cin >15 then will it not overshoot the until and never make the statement true ? Maybe UNTIL i >= k would be better ?
Looked at the data sheet, no schmitt triggers to worry about, porta on change interrupts are available. I notice your code does not loop, one shot as is. I really did not write any code <font color=red>AND I DID NOT TEST THIS,</font color> but here is what I was thinking you might do differently. I would actually make the int handler a bit smaller and tidier but you get the jist.
Code:' -----[ Title ]---------------------------------------------------------- -* ' * ' File...... Toilet_Meter.BAS * ' Compiler.. PICBASIC PRO Compiler from microEngineering Labs * ' Purpose... PIC16F690 microcontroller for Toilet Meter Project * ' Author.... John R. Ellis, * ' Started... 2/20/2009 * ' * ' Updated... Version 1.0.6 on 5/2/2009 * ' Program Size: 255 Words * * ' -----[ Program Description ]---------------------------------------------* ' This Program is for a PIC16F690 installed in a PICkit2 Starter Kit * ' Purpose: ' 1) Monitor an input for an external Interrupt from flush * ' 2) On Interrupt, command latching solenoid to open valve * ' 3) Measure flow meter output to determine when 1.6 * ' gallons have passed * ' 4) On 1.6 gallons, command latching solenoid to close * ' 5) Put Microcontroller back in Sleep State to await next * ' Flush Interrupt * ' ' This Program uses the PIC16F690 to control a solenoid operated water valve ' and to measure the volume of water flowing through a flow meter. ' This program places the MCU in sleep mode most of the time until it receives ' an interrupt from the activation of the toilet flush handle that closes a ' contact limit switch that grounds an input pin of the microcontroller as an ' interrupt. I/O pin connections to the PIC16F690 are as follows: ' ' RA1...is connected as an input from the meter to count pulse inputs, which ' are simulated by multiple manual depressions of a switch on the PICKIT2 ' demo board during program testing. ' RA3...is connected as an interrupt input from the FLUSH contact limit Switch. ' RC0...is connected as an output to an LED and is slowly flashed when the valve ' is open. It is also flashed even more slowly when the battery is low. ' RC3...is connected as an output to the latching solenoid that opens or ' closes the valve. During program testing with the PICkit2 demo ' board it is connected to an LED to show when the pulse is sent. ' -----[ Device Declaration ]---------------------------------------------- ' '@device pic16F690, intrc_osc_noclkout, BOD_OFF, PWRT_OFF, wdt_off,mclr_off, ' protect_off ' -----[ Revision History ]------------------------------------------------ @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF ' -----[ Variables Initialization ]---------------------------------------- ' k CON 15 ' Calibration factor for flow meter...# pulses per gal i VAR Byte ' Index used in Gallon counter Repeat...Until loop Cin VAR Byte ' Storage variable for count from COUNTER ' -----[ Initialization ]-------------------------------------------------- ' 'Registers Settings Init: ADCON1 = %01110000 ' Set PORTA to digital I/O & FRC (clock derived from a dedicated internal oscillator) ' TRISA = %00000010 ' Set all PORTA pins except RA1 to outputs TRISB = %00000000 ' Set all PORTB and PORTC pins to outputs TRISC = %00000000 PORTC = %00000000 ' Pre-set PORTB pins low, turning LEDs off ANSEL = 0 ' Set PortA to digital I/O; Unselect any of the A/D channels ANSELH = 0 TRISA.1 = 1 ' Set RA1 as input port for meter pulse inputs PortA.1 = 0 ' Pre-set RA1 at Low value INTCON = %10011000 ' Set INTCON register to enable interrupts ' -----[ Main Code ]------------------------------------------------------- on interrupt goto Int_Handler MAIN: 'Send PWM pulse to latching solenoid to open valve 'Generates 10 millisec pulse on RC3 output pin LOW PORTC.3 ' Initialize output pulse polarity PULSOUT PORTC.3,1000 ' Generate 10 msec pulse to RC3 ' Valve should be open at this point and water flowing Log: WRITE 7,i 'Store result as test of code..not in production 'Write 8,i.LowByte GoTo ShutValve ShutValve: ' Send PWM pulse to latching solenoid to close valve PULSOUT PORTC.3,1000 ' Generate required 10 msec pulse to RC3 @ sleep Disable ' Valve should be closed at this point and no water flowing Int_Handler: ' Start measuring output of flow meter at RA1 input pin Cin = 0 ' Initialize pulse count variable to zero i = 0 ' Initialize total pulse count index to zero REPEAT ' Assume it takes k accumulated pulses for required gallons ' Count the number of pulses from Hall Effect Magnetic Sensor in 5 sec ' epochs and add count from each epoch to total accumulation and then ' shutoff the valve when count meets i>k criteria. Count PORTA.1,5000,Cin WRITE 5,Cin ' Write count into EEPROM location 5 during ' pre-production testing ' Slowly blink LED during water flow HIGH PORTC.0 ' If we get here, Blink the LED once PAUSE 100 LOW PORTC.0 i = i + Cin ' Add count to total pulse accumulation indexer 'When i >= k, required gallons have flowed by the meter UNTIL i >= k goto Log return enable END
