Count button presses
Results 1 to 5 of 5
    Nov 2007
    Default Count button presses
    I have my project setup to check for button presses on a pin. Simple IF *** = 0 THEN ****
    I would like to be able to count the button presses like if 3 button presses are made within a certain time, it would set a variable to 3. If pressed 5 times, set said variable to 5 and so on.
    Right now my code is setup to just add to the current variable every time the button is pressed. The problem is that I have it flash an LED to confirm what setting it's on and since it immediately add's to the variable, then checks the variable, you can't just tap the button 4 quick times and jump to setting 4.
    Any help would be great.
    Talking
    Only solution : , index on LCD or Bargraph or LED Display of the number !!!
    Or use a "Rainbow led" ... and display with resistor's code !!!
    Hi. If I understand correctly, something like this should allow you to push the button numerous times while advancing your mode with each push. Unfortunately, I’m at work now & can’t test it. It looks to me like it should work.
    START:
    CLEAR 'ALL VARIABLES = 0
    IF PORTA.0 = 1 THEN START 'BUTTON NOT PUSHED STAY HERE
    MODE:
    LET TIMER = 0 ‘RESET TIMER
    LET MODENUMBER = (MODENUMBER + 1) 'ADVANCE MODE
    WAITFORRELEASE:
    PAUSE 25 'DEBOUNCE
    IF PORTA.0 = 0 THEN WAITFORRELEASE 'BUTTON STILL PUSHED WAIT HERE
    BUTTONTIMER:
    IF PORTA.0 = 0 THEN MODE 'ADVANCE MODE IF BUTTON PUSHED AGAIN
    LET TIMER = (TIMER + 1)
    PAUSE 10
    IF TIMER >= 500 THEN SIGNALMODE 'AFTER 5 SECONDS SIGNAL THE MODE NUMBER
    GOTO BUTTONTIMER
    SIGNALMODE:
    HIGH PORTB.0 'LIGHT UP LED OR BEEP PIEZO BUZZER
    PAUSE 250
    LOW PORTB.0 'OFF LED OR SOUNDER
    PAUSE 250
    LET SIGNAL = (SIGNAL + 1)
    IF SIGNAL < MODENUMBER THEN SIGNALMODE 'KEEP FLASHING OR BEEPING
    GOTO (YOUR MAIN PROGRAM)
    If you have only 1 push button, you could use an internal timer/counter. This one will increase each time you press on the switch (may need some external debouncing). You could also use an interruptible pin, says INT0, and within your ISR, you increase your counter value and process the Debouncing.
    A timer interrupt, or polling a timer overflow to check the Counter value, and you're all set.
    Nov 2007
    I will try the example above. If anyone else has any other suggestions please let me know.
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  3. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  4. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  5. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
