PIC16f690 LCD Not Working
Results 1 to 20 of 20
    I applied Joe's code and still can't bring my display to work with this chip (I tried with three).
    Never had problems with other chips.
    Don't know what's wrong :-/
    What are you getting Roger ? Blocks , anything ?
    Checked it again, and it's fine. here is the hex:
    SWITZERLAND (french speaking)
    Sorry, I'm wrong, it worked for me too.. in the past, also with 16F690.
    I may have a problem with my breadboards. Gonna buy a new one today.
    Nevertheless, what I see on my LCD display is on it's first line, a row of blocks, slightly visible.
    Of course, I tried to change the contrast, but nothing helps.
    Roger
    I never use a contrast pot, I ground pins 1,3,5,16, put power on 2,15 always works for me. Those breadboards get nasty inside, corrosion after the plating wears a bit, the component pins wear the contacts quickly too.
    No pot on my side too.
    I use a 1k2 to 2k2 resitor instead.
    Must be the breadboards...
    Roger
    May 2009
    Still not working!
    Just get a row of black blocks.
    any one else able to get this working yet?
    Quote Originally Posted by hhosteam View Post
    Still not working!
    Just a row of blocks indicates either contrast is too far + or no pic signal. Not meaning to offend or agitate, but you did look at the pic pinout in the data sheet, yes? I ask because this PIC has a somewhat convoluted pin arrangement and it is easy to wire it incorrectly. Is your programmer up to this chips needs? Most PICs like 16F84, 16F628 . .. have power in the center of the device but this has them swapped side for side and at 1 end, your programmer might not know this. I programmed mine using PICKitII and low parts count demo board made for 16F690. You might have to set up for ICSP to properly program it.
  1. 2x16 lcd not working with pic16f72
    By vu2iia in forum Schematics
    Last Post: - 16th February 2011, 15:59
  2. My LCD code is not working...
    By kvrajasekar in forum mel PIC BASIC
    Last Post: - 7th December 2008, 06:41
  3. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 21:05
  4. Simple LCD code not working..
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 28th April 2008, 14:55
  5. SOUND makes LCD quit working
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 18th April 2008, 15:12
