PIC16f690 LCD Not Working
Results 1 to 20 of 20
    SWITZERLAND (french speaking)
    Default same problem for me...
    I applied Joe's code and still can't bring my display to work with this chip (I tried with three).
    Never had problems with other chips.
    Don't know what's wrong :-/
    Roger
    What are you getting Roger ? Blocks , anything ?
    Checked it again, and it's fine. here is the hex:
    Sorry, I'm wrong, it worked for me too.. in the past, also with 16F690.
    I may have a problem with my breadboards. Gonna buy a new one today.
    Nevertheless, what I see on my LCD display is on it's first line, a row of blocks, slightly visible.
    Of course, I tried to change the contrast, but nothing helps.
    Roger
    I never use a contrast pot, I ground pins 1,3,5,16, put power on 2,15 always works for me. Those breadboards get nasty inside, corrosion after the plating wears a bit, the component pins wear the contacts quickly too.
    No pot on my side too.
    I use a 1k2 to 2k2 resitor instead.
    Must be the breadboards...
    Roger
    May 2009
    Still not working!
    Just get a row of black blocks.
    any one else able to get this working yet?
  1. 2x16 lcd not working with pic16f72
    By vu2iia in forum Schematics
    Last Post: - 16th February 2011, 15:59
  2. My LCD code is not working...
    By kvrajasekar in forum mel PIC BASIC
    Last Post: - 7th December 2008, 06:41
  3. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 21:05
  4. Simple LCD code not working..
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 28th April 2008, 14:55
  5. SOUND makes LCD quit working
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 18th April 2008, 15:12
