PIC16f690 LCD Not Working
Results 1 to 20 of 20
    Are you using this chip on a solderless breadboard or are you using the Low Pin Count Demo Board from Microchip ?
    this is you code with only minor tweeks and it works on a solderless breadboard. try grounding the contrast pin #3 on the lcd. This is compiled using MPASM as it is what I always use.
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF &_CP_OFF
    define OSC 4
    DEFINE LCD_DREG PORTC 'Set port C for the data lines
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB 'Set the RS Port and Pin
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTB 'Set LCD Enable bit and pin
    DEFINE LCD_EBIT 6
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 2000
    ' Set data delay time in us
    DEFINE LCD_DATAUS 50
    ANSEL = 0
    ANSELH = 0
    CM1CON0 = 0
    CM2CON0 = 0
    Cnt VAR WORD
    'Start Program
    TRISC = 0
    TRISB = 0
    Pause 500
    cnt=0
    RPT:
    HIGH PORTB.6
    LCDOUT $FE,1 'CLEAR LCD SCREEN
    LCDOUT $FE,2,"CNT=", DEC CNT
    Pause 1000
    CNT=CNT+1
    GOTO RPT
    SWITZERLAND (french speaking)
    Default same problem for me...
    I applied Joe's code and still can't bring my display to work with this chip (I tried with three).
    Never had problems with other chips.
    Don't know what's wrong :-/
    Roger
    What are you getting Roger ? Blocks , anything ?
    Checked it again, and it's fine. here is the hex:
    Sorry, I'm wrong, it worked for me too.. in the past, also with 16F690.
    I may have a problem with my breadboards. Gonna buy a new one today.
    Nevertheless, what I see on my LCD display is on it's first line, a row of blocks, slightly visible.
    Of course, I tried to change the contrast, but nothing helps.
    Roger
    I never use a contrast pot, I ground pins 1,3,5,16, put power on 2,15 always works for me. Those breadboards get nasty inside, corrosion after the plating wears a bit, the component pins wear the contacts quickly too.
    No pot on my side too.
    I use a 1k2 to 2k2 resitor instead.
    Must be the breadboards...
    Roger
  1. 2x16 lcd not working with pic16f72
    By vu2iia in forum Schematics
    Last Post: - 16th February 2011, 14:59
  2. My LCD code is not working...
    By kvrajasekar in forum mel PIC BASIC
    Last Post: - 7th December 2008, 05:41
  3. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 20:05
  4. Simple LCD code not working..
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 28th April 2008, 13:55
  5. SOUND makes LCD quit working
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 18th April 2008, 14:12
