16F616 A to D
Results 1 to 4 of 4
Thread: 16F616 A to D
    Default 16F616 A to D
    I can't seem to get the A/D to work correctly. I have tried different configs yet no luck. The pin I am using to measure voltage is RC0/AN4/C2IN+. So I configure the pin to analogue with ANSEL.4=1, disable the comparator with CM2CON0.7=0 and select the analogue bit with ADCON0.5-2.
    I check voltage at the pin with my scope and its .650v. Yet debugging I get a value of '0' with any input from 0-5v. Any input is appreciated.
    INCLUDE "modedefs.bas"
    FF           var PortC.0
    FrontOut     var PortC.1
    RearOut      var PortC.2
    Voltage      var word
    Perfect      var word
    define OSC 20
    DEFINE DEBUG_REG PortC          'SET DEBUG PIN PORT
    DEFINE DEBUG_BIT 5             'SET DEBUG PIN BIT
    DEFINE DEBUG_BAUD 9600         'SET DEBUG BAUD RATE
    DEFINE DEBUG_MODE 1            'SET DEBUG MODE 0=TRUE / 1=INVERTED
    Define ADC_SAMPLEUS 10 ' Set sampling time in uSec
    TRISC.0 = 1  'FF (Flip/Flop)
    TRISC.1 = 0  'FrontOut
    TRISC.2 = 0  'RearOut
    '0 Digital 1 Analogue
    ANSEL.6=0 'RearOut
    ANSEL.5=0 'FrontOut
    ANSEL.4=1 'FF
    CM2CON0.7=0 'Disable comparator
    ADCON0.7=1 'Right Justified
    ADCON0.6=0 ''Voltage reference is VDD
    ADCON0.5=0 'Turns on AN4 to analogue
    ADCON0.4=1
    ADCON0.3=0
    ADCON0.2=0
    ADCON0.0=1
    Perfect = 512
    Loop:
      GOSUB Get_Voltage
      gOSUB Compare
      debug "Voltage=", DEC VOltage, cr
    Goto Loop
    Get_Voltage:
    ADCIN FF, Voltage
    Compare:
    If Voltage < Perfect then
       Low FrontOut
    If Voltage > Perfect then
       Low RearOut
    You have capture compare registers to deal with, and others. CCP1CON, CM1CON0,CM2CON0, CM2CON1, ADCON1
    Am I doing the ADCON0.x correctly?
    I added CM1CON0.7=0 so both comparators are disabled.
    I still get Voltage=0 when I debug.
    FF var PortC.0
    RearOut var PortC.2
    Voltage var word
    Perfect var word
    define OSC 20
    DEFINE DEBUG_BIT 5
    DEFINE DEBUG_MODE 1
    Define ADC_BITS 10
    Define ADC_CLOCK 3
    ANSEL.6=0 'RearOut
    ANSEL.5=0 'FrontOut
    ANSEL.4=1 'FF
    CM1CON0.7=0
    ADCON0.6=0 'Voltage reference is VDD
    ADCON0.4=1
    ADCON0.3=0
    ADCON0.2=0
    ADCON0.0=1
    CCP1CON.3=0
    CCP1CON.2=0
    CCP1CON.1=0
    CCP1CON.0=0
    Perfect = 512
    Loop:
    GOSUB Get_Voltage
    gOSUB Compare
    Goto Loop
    Get_Voltage:
    ADCIN FF, Voltage
    Compare:
    Low FrontOut
    Low RearOut
    When you use ADCIN you must use the Channel #, not the PORT pin name.
    ADCIN 4, Voltage ' PORTC.0 = AN4
  1. PIC 16F616 Interrupt Enable/Disable?
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 17th May 2009, 09:17
  2. Configuring 16F616
    Last Post: - 16th February 2009, 17:28
  3. PIC16f628 to PIC16f616
    By JimA in forum General
    Last Post: - 22nd October 2007, 15:33
  4. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 16:05
