batteries
Results 1 to 3 of 3
Thread: batteries
    Nov 2004
    Saskatchewan Canada
    Question batteries
    Anyone using or know of a battery that might be small enough to fit into an area, let's say 1x1x.5 inches (I don't have the exact measurement, but suffice to say small area)?
    Would need to be 4.5v minimum, 5.5 ideal and pack as much juice as possible. Doesn't need to be rechargeable, but cost would be somewhat of an issue.
    I am trying to determine if I can squeeze all the compents I would need for my next big project into next to nothing for space.
    Any ideas of leads would be appreciated.
    Thanks.
    Bart
    Feb 2004
    Germany
    Bart,
    If it is only size and cost (and not capacity) that matters there are hundreds of options:
    ie. two standard Lithium Coin Cells in series.
    Or one of the many "high voltage" batteries used in remote controls, cameras, etc.
    i.e. GP11A or GP476A
    for more information: Click here
    regards
    Ralph
    Nov 2004
    Saskatchewan Canada
    While size is the primary factor there still has to be sufficient juice so the coin cells are not an option. I've been sort of looking at around 600 MA just as a starting point although perhaps it doesn't need to be even that much. I have to run 14 LEDs (most small 2mm sizes), drive a speaker through a chipcorder plus the control PIC. Ideally the battery should last 30 minutes (not all sounds and LEDs are on all the time). Fifteen minutes would be the shortest time I would want to go with.
    I have been looking to the point of dizzy with all the batteries out there. Always finding case of MA being good, but size being too big or size being good and MA being too low.
    I'll check out your link.
    Thanks.
    Bart
  1. Replies: 14
    Last Post: - 6th March 2011, 06:08
  2. Generating 5v from 4 batteries
    By BobP in forum Off Topic
    Last Post: - 27th December 2009, 10:46
  3. Utility of 0,1µF capa when batteries are used
    Last Post: - 27th April 2009, 11:09
  4. schematic for rechargeable batteries
    By PoTeToJB in forum Schematics
    Last Post: - 11th May 2006, 18:36
  5. Measure the voltage of my rc batteries
    Last Post: - 10th February 2006, 08:59
